CyberPoison 33 Posted March 4, 2021 Posted March 4, 2021 (edited) Hi everyone, it was been for a while now than MKV and TS supports Dolby Vision i'm wondering if why the LG Player was not update consequently with those updates ? Anyone know if this was a fault of LG or a Fault of Emby ? If it was a fault of LG, can Emby do some check with LG ? My tv is the LG C9 JFI Just a other push up to say than the LG app stay very slow with big library, waiting those update since a year. Please Emby staff let us know how is going the Emby update on the LG review proces. Edited April 27, 2021 by CyberPoison
SamES 1084 Posted March 5, 2021 Posted March 5, 2021 12 hours ago, CyberPoison said: Hi everyone, it was been for a while now than MKV and TS supports Dolby Vision i'm wondering if why the LG Player was not update consequently with those updates ? Anyone know if this was a fault of LG or a Fault of Emby ? If it was a fault of LG, can Emby do some check with LG ? My tv is the LG C9 JFI Hi, can you please share an example. Just be aware that for DolbyVision to work correctly, you will need to ensure the movie is using DirectPlay. If it is transcoding then it won't be possible. Also have a look at this discussion [FEATURE REQUEST] Dolby Vision support for MKV in LG TV app - Feature Requests - Emby Community You can try playing your movie via a USB drive with the built-in player to confirm if the format is supported by the TV.
rbjtech 5341 Posted March 6, 2021 Posted March 6, 2021 I've tried via USB on an LG C8 and it plays single and double layer Dolby Vison MKV's as HDR10 only. Given DoVi via MKV is only recently possible, it's not surprising. Maybe worth trying .MP4 ? 1
CyberPoison 33 Posted March 7, 2021 Author Posted March 7, 2021 On 3/6/2021 at 1:41 PM, rbjtech said: I've tried via USB on an LG C8 and it plays single and double layer Dolby Vison MKV's as HDR10 only. Given DoVi via MKV is only recently possible, it's not surprising. Maybe worth trying .MP4 ? On 3/5/2021 at 12:53 PM, SamES said: Hi, can you please share an example. Just be aware that for DolbyVision to work correctly, you will need to ensure the movie is using DirectPlay. If it is transcoding then it won't be possible. Also have a look at this discussion [FEATURE REQUEST] Dolby Vision support for MKV in LG TV app - Feature Requests - Emby Community You can try playing your movie via a USB drive with the built-in player to confirm if the format is supported by the TV. Only works mp4 with emby (No transcoding on files even on mkv) but mkv says than it's HDR10 when the movie is at normally Dolby Vision and same thing for files with ts containers, Also I want to advert then I don't allow transcoding on my emby server so don't worry the files play automatically in directly play format.
CyberPoison 33 Posted March 15, 2021 Author Posted March 15, 2021 On 3/5/2021 at 12:53 PM, SamES said: Hi, can you please share an example. Just be aware that for DolbyVision to work correctly, you will need to ensure the movie is using DirectPlay. If it is transcoding then it won't be possible. Also have a look at this discussion [FEATURE REQUEST] Dolby Vision support for MKV in LG TV app - Feature Requests - Emby Community You can try playing your movie via a USB drive with the built-in player to confirm if the format is supported by the TV. Yeah but I have a movie which play as DolbyVision is an mp4 and mp4 is supported on LG C9 for DolbyVision You can see info here 9 minutes ago, CyberPoison said: Don't worry about that cable management is fully temporary because I gona move to other apartments where the cabling management is in walls directly . BTW and what about Apple TV, IPhone and all other devices, on my mobile it shows colors like purple and green on face and clouth. I will go to turn my server back in beta since is a issue with the media play I thought it was a issue with server side so I reversed back to latest so now I put it back to beta. I'm very excited about support for Dolby Vision in mobile and etc... IOS and most 99% recent devices support it (Avoid Samsung OK their have done a very dumb choice I'm not aware about what they do) This is my movies encoding détails but looks like also a IMAX with DolbyVision such as maybe not supported. There is two layers but the movies original name is: Mission.Impossible.Fallout.2018.MULTI.IMAX.2160p.DOLBY.VISION.UHD.BluRay.REMUX.DD5.1.HEVC-ABF IMAX and DolbyVision it's a MP4 it have a sample which unfortunately the link is no more available. But it works on LG C9 Plex only on with emby doesn't works and on ATV not works by PLEX or EMBY I gona send a report from my Emby can @ebr and @Luke CyberPoison sent from my app which is the latest beta tester app. 18:14 gmt+1 from my ATV emby beta latest app. Please check your logs from emby ATV app I also sent a logs from bones which is a AVI format than don't works I already open a ticket about it somewhere, but just say than I send a other logs about Bones (CyberPoison) avi container which don't load at all at 18h17 gmt+1 This movies works on plex native LG C9 apps but not in emby LG app can you check this tell me if there is a way to send logs? 4 minutes ago, CyberPoison said: And what about LG C9 native app the movie above works as Dolby Vision but not on emby this is weird
SamES 1084 Posted March 15, 2021 Posted March 15, 2021 On 05/03/2021 at 22:53, SamES said: You can try playing your movie via a USB drive with the built-in player to confirm if the format is supported by the TV. Did you try this, if it doesn't work then there is nothing we can do. If it does, then it should already work as long as you DirectPlay (which won't be possible if it is a TrueHD or DTS track, or PGS subs)
CyberPoison 33 Posted April 24, 2021 Author Posted April 24, 2021 (edited) As I can see mp4 single layer and double return a green bizarre image on LG TV but with plex it plays fine, both single and dual layer. @SamES Plex return DolbyVision on both single and dual layer while the LG Emby app return a green image like show above my format is mp4. Edited April 24, 2021 by CyberPoison
CyberPoison 33 Posted April 24, 2021 Author Posted April 24, 2021 On 3/6/2021 at 1:41 PM, rbjtech said: I've tried via USB on an LG C8 and it plays single and double layer Dolby Vison MKV's as HDR10 only. Given DoVi via MKV is only recently possible, it's not surprising. Maybe worth trying .MP4 ? the movie above is mp4 single layer and it show me green images unfortunately
SamES 1084 Posted April 24, 2021 Posted April 24, 2021 So I'm not quite sure what you want here. Did you try this? On 3/5/2021 at 6:53 AM, SamES said: You can try playing your movie via a USB drive with the built-in player to confirm if the format is supported by the TV. We/you need to determine: Can the TV play this directly from the USB as you expect it to - you need to test and confirm this? If it can, then we can look further into why it is not playing correctly via the app If it cannot, then we need to transcode it This won't work for you as you have turned off. This is not really a good idea as you are forcing the TV and other clients to DirectPlay files that the devs have determined cannot be DirectPlayed. You are really then trying to do something that might not even be possible. Transcoding will probably result in the loss of HDR or DV, etc, so this still won't meet your needs. If it does not working via USB connected to the TV, but it does work in Plex (with the Plex LG client or using XPlay?) with DV and HDR then it is possible that they are using a 3rd party player and not the build in player that is used by the Emby client on the LG TV.
CyberPoison 33 Posted April 27, 2021 Author Posted April 27, 2021 (edited) Hi it works well under the build in player. You can see a video footage from it working on the TV done my self here: https://drive.google.com/file/d/1koReVWU9MOm04gEVufa-GuUBaQaTmUWl/view?usp=sharing ``` ffmpeg info when making the sample. Quote Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'C:\Users\Administrator\Desktop\Zack Snyder's Justice League (2021)\Zack Snyder's Justice League (2021).mp4': Metadata: major_brand : isom minor_version : 1 compatible_brands: isom creation_time : 2021-03-18T21:28:28.000000Z copyright : copyright-eng : Duration: 04:02:08.16, start: 0.000000, bitrate: 19369 kb/s Chapters: Chapter #0:0: start 0.000000, end 51.000000 Metadata: title : 1. Studio Logo 01 Chapter #0:1: start 51.000000, end 156.000000 Metadata: title : Scene 2 Chapter #0:2: start 156.000000, end 184.000000 Metadata: title : Scene 3 Chapter #0:3: start 184.000000, end 233.000000 Metadata: title : Scene 4 Chapter #0:4: start 233.000000, end 285.000000 Metadata: title : Scene 5 Chapter #0:5: start 285.000000, end 376.000000 Metadata: title : Scene 6 Chapter #0:6: start 376.000000, end 836.000000 Metadata: title : Scene 7 Chapter #0:7: start 836.000000, end 900.000000 Metadata: title : Scene 8 Chapter #0:8: start 900.000000, end 955.000000 Metadata: title : Scene 9 Chapter #0:9: start 955.000000, end 1050.000000 Metadata: title : Scene 10 Chapter #0:10: start 1050.000000, end 1519.000000 Metadata: title : Scene 11 Chapter #0:11: start 1519.000000, end 2220.000000 Metadata: title : Scene 12 Chapter #0:12: start 2220.000000, end 2291.000000 Metadata: title : Scene 13 Chapter #0:13: start 2291.000000, end 2380.000000 Metadata: title : Scene 14 Chapter #0:14: start 2380.000000, end 2497.000000 Metadata: title : Scene 15 Chapter #0:15: start 2497.000000, end 2632.000000 Metadata: title : Scene 16 Chapter #0:16: start 2632.000000, end 2699.000000 Metadata: title : Scene 17 Chapter #0:17: start 2699.000000, end 2804.000000 Metadata: title : Scene 18 Chapter #0:18: start 2804.000000, end 2847.000000 Metadata: title : Scene 19 Chapter #0:19: start 2847.000000, end 3024.000000 Metadata: title : Scene 20 Chapter #0:20: start 3024.000000, end 3380.000000 Metadata: title : Scene 21 Chapter #0:21: start 3380.000000, end 3528.000000 Metadata: title : Scene 22 Chapter #0:22: start 3528.000000, end 4121.000000 Metadata: title : Scene 23 Chapter #0:23: start 4121.000000, end 4411.000000 Metadata: title : Scene 24 Chapter #0:24: start 4411.000000, end 4504.000000 Metadata: title : Scene 25 Chapter #0:25: start 4504.000000, end 4561.000000 Metadata: title : Scene 26 Chapter #0:26: start 4561.000000, end 4621.000000 Metadata: title : Scene 27 Chapter #0:27: start 4621.000000, end 5274.000000 Metadata: title : Scene 28 Chapter #0:28: start 5274.000000, end 5411.000000 Metadata: title : Scene 29 Chapter #0:29: start 5411.000000, end 5644.000000 Metadata: title : Scene 30 Chapter #0:30: start 5644.000000, end 5774.000000 Metadata: title : Scene 31 Chapter #0:31: start 5774.000000, end 5972.000000 Metadata: title : Scene 32 Chapter #0:32: start 5972.000000, end 6034.000000 Metadata: title : Scene 33 Chapter #0:33: start 6034.000000, end 6085.000000 Metadata: title : Scene 34 Chapter #0:34: start 6085.000000, end 6141.000000 Metadata: title : Scene 35 Chapter #0:35: start 6141.000000, end 6163.000000 Metadata: title : Scene 36 Chapter #0:36: start 6163.000000, end 6198.000000 Metadata: title : Scene 37 Chapter #0:37: start 6198.000000, end 6580.000000 Metadata: title : Scene 38 Chapter #0:38: start 6580.000000, end 6609.000000 Metadata: title : Scene 39 Chapter #0:39: start 6609.000000, end 6689.000000 Metadata: title : Scene 40 Chapter #0:40: start 6689.000000, end 6814.000000 Metadata: title : Scene 41 Chapter #0:41: start 6814.000000, end 7367.000000 Metadata: title : Scene 42 Chapter #0:42: start 7367.000000, end 7582.000000 Metadata: title : Scene 43 Chapter #0:43: start 7582.000000, end 7681.000000 Metadata: title : Scene 44 Chapter #0:44: start 7681.000000, end 7722.000000 Metadata: title : Scene 45 Chapter #0:45: start 7722.000000, end 7897.000000 Metadata: title : Scene 46 Chapter #0:46: start 7897.000000, end 8195.000000 Metadata: title : Scene 47 Chapter #0:47: start 8195.000000, end 8430.000000 Metadata: title : Scene 48 Chapter #0:48: start 8430.000000, end 8516.000000 Metadata: title : Scene 49 Chapter #0:49: start 8516.000000, end 8726.000000 Metadata: title : Scene 50 Chapter #0:50: start 8726.000000, end 8747.000000 Metadata: title : Scene 51 Chapter #0:51: start 8747.000000, end 8839.000000 Metadata: title : Scene 52 Chapter #0:52: start 8839.000000, end 8997.000000 Metadata: title : Scene 53 Chapter #0:53: start 8997.000000, end 9064.000000 Metadata: title : Scene 54 Chapter #0:54: start 9064.000000, end 9147.000000 Metadata: title : Scene 55 Chapter #0:55: start 9147.000000, end 9213.000000 Metadata: title : Scene 56 Chapter #0:56: start 9213.000000, end 9222.000000 Metadata: title : Scene 57 Chapter #0:57: start 9222.000000, end 9597.000000 Metadata: title : Scene 58 Chapter #0:58: start 9597.000000, end 10126.000000 Metadata: title : Scene 59 Chapter #0:59: start 10126.000000, end 10393.000000 Metadata: title : Scene 60 Chapter #0:60: start 10393.000000, end 10537.000000 Metadata: title : Scene 61 Chapter #0:61: start 10537.000000, end 10707.000000 Metadata: title : Scene 62 Chapter #0:62: start 10707.000000, end 10901.000000 Metadata: title : Scene 63 Chapter #0:63: start 10901.000000, end 11055.000000 Metadata: title : Scene 64 Chapter #0:64: start 11055.000000, end 11130.000000 Metadata: title : Scene 65 Chapter #0:65: start 11130.000000, end 11192.000000 Metadata: title : Scene 66 Chapter #0:66: start 11192.000000, end 11315.000000 Metadata: title : Scene 67 Chapter #0:67: start 11315.000000, end 11842.000000 Metadata: title : Scene 68 Chapter #0:68: start 11842.000000, end 11870.000000 Metadata: title : Scene 69 Chapter #0:69: start 11870.000000, end 12508.000000 Metadata: title : Scene 70 Chapter #0:70: start 12508.000000, end 12599.000000 Metadata: title : Scene 71 Chapter #0:71: start 12599.000000, end 12746.000000 Metadata: title : Scene 72 Chapter #0:72: start 12746.000000, end 12846.000000 Metadata: title : Scene 73 Chapter #0:73: start 12846.000000, end 13204.000000 Metadata: title : Scene 74 Chapter #0:74: start 13204.000000, end 13427.000000 Metadata: title : Scene 75 Chapter #0:75: start 13427.000000, end 13842.000000 Metadata: title : Scene 76 Chapter #0:76: start 13842.000000, end 14002.000000 Metadata: title : Scene 77 Chapter #0:77: start 14002.000000, end 14013.000000 Metadata: title : 78. Acknowledgement Chapter #0:78: start 14013.000000, end 14528.160000 Metadata: title : 79. End Credits Stream #0:0(eng): Video: hevc (Main 10) (dvhe / 0x65687664), yuv420p10le(pc), 3840x2160 [SAR 1:1 DAR 16:9], 17957 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 23.98 tbc (default) Metadata: creation_time : 2021-03-18T20:20:08.000000Z handler_name : WEB 4K Dolby Vision MZABI (Thx) vendor_id : [0][0][0][0] encoder : DOVI Coding Side data: DOVI configuration record: version: 1.0, profile: 5, level: 6, rpu flag: 1, el flag: 0, bl flag: 1, compatibility id: 0 Stream #0:1(fra): Audio: eac3 (ec-3 / 0x332D6365), 48000 Hz, 5.1(side), fltp, 640 kb/s (default) Metadata: handler_name : French (VFF) Dolby Digital Plus 5.1 @ 640 Kbps(Cut FrIeNdS) (Thx to LOST) vendor_id : [0][0][0][0] Side data: audio service type: main Stream #0:2(eng): Audio: eac3 (ec-3 / 0x332D6365), 48000 Hz, 5.1(side), fltp, 768 kb/s (default) Metadata: handler_name : English Dolby Digital Plus 5.1 with Dolby Atmos @ 768 Kbps vendor_id : [0][0][0][0] Side data: audio service type: main Stream #0:3(fra): Subtitle: mov_text (tx3g / 0x67337874), 3840x2160 (default) Metadata: creation_time : 2021-03-18T21:33:51.000000Z handler_name : French Forced Stream #0:4(fra): Subtitle: mov_text (tx3g / 0x67337874), 3840x2160, 0 kb/s (default) Metadata: creation_time : 2021-03-18T21:33:51.000000Z handler_name : French Stream #0:5(eng): Subtitle: mov_text (tx3g / 0x67337874), 3840x2160, 0 kb/s (default) Metadata: creation_time : 2021-03-18T21:33:51.000000Z handler_name : Full English [mp4 @ 000001695f9a02c0] track 1: codec frame size is not set Output #0, mp4, to 'C:\Zack Snyder's Justice League 2021 2016 Dolby Vision .mp4': I will try also others movies to check this out. there is the sample file for Zack Snyder's Justice League (2021).mp4 from the ffmpeg info above. its around 800mb https://drive.google.com/file/d/1JJSxF-K-VhUfUTQXEJcuRNqZ0WFRtERz/view?usp=sharing Edited April 27, 2021 by CyberPoison 1
CyberPoison 33 Posted April 27, 2021 Author Posted April 27, 2021 (edited) @SamES Also to inform than tomorrow will test more movies under MKV and MP4 dual layer and single to check what of them works Edited April 28, 2021 by CyberPoison
SamES 1084 Posted April 27, 2021 Posted April 27, 2021 OK, thanks. Can you please try again in Emby on the details screen before you start playback, please turn off subtitles and make sure the first audio track is selected?
SamES 1084 Posted April 27, 2021 Posted April 27, 2021 and attach any logs from this playback session
CyberPoison 33 Posted April 28, 2021 Author Posted April 28, 2021 (edited) Hi there is the logs you have requested if i understood well 2021-04-28 10:14:50.564 Info Server: http/1.1 Response 200 to 188.37.103.92. Time: 18ms. http://192.168.1.5/emby/LiveTv/Channels?UserId=7770f5849af24b8db1aaac4d4512c9b0&IsAiring=true&Limit=24&ImageTypeLimit=1&EnableImageTypes=Primary,Thumb,Backdrop&EnableTotalRecordCount=false&Fields=ProgramPrimaryImageAspectRatio&EnableUserData=false&SortBy=ChannelNumber,SortName&X-Emby-Client=Emby Web&X-Emby-Device-Name=Opera&X-Emby-Device-Id=8f33a29a-ea12-4632-8ef1-f6a6b01c038c&X-Emby-Client-Version=4.6.0.40 2021-04-28 10:15:09.479 Debug SessionManager: Removing active session Chrome 3f733e16-7377-4f6a-b56d-5fc529a6dda2 2021-04-28 10:15:09.479 Debug SessionManager: Disposing session controller WebSocketController 2021-04-28 10:15:42.302 Info Server: http/1.1 GET http://192.168.1.5/emby/system/info/public. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:42.303 Info Server: http/1.1 Response 200 to 192.168.1.1. Time: 0ms. http://192.168.1.5/emby/system/info/public 2021-04-28 10:15:42.347 Info Server: http/1.1 GET http://192.168.1.5/emby/web/manifest.json. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:42.348 Info Server: http/1.1 GET http://192.168.1.5/emby/web/strings/en-US.json. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:42.348 Info Server: http/1.1 Response 200 to 192.168.1.1. Time: 0ms. http://192.168.1.5/emby/web/manifest.json 2021-04-28 10:15:42.348 Info Server: http/1.1 Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.5/emby/web/strings/en-US.json 2021-04-28 10:15:42.415 Info Server: http/1.1 GET http://192.168.1.5/emby/System/Info. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:42.419 Debug XmlSerializer: Serializing to file /config/plugins/configurations/MessageUsers.xml 2021-04-28 10:15:42.420 Debug XmlSerializer: Serializing to file /config/plugins/configurations/MessageUsers.xml 2021-04-28 10:15:42.420 Info Server: http/1.1 Response 200 to 192.168.1.1. Time: 5ms. http://192.168.1.5/emby/System/Info 2021-04-28 10:15:42.464 Info Server: http/1.1 GET http://192.168.1.5/emby/DisplayPreferences/usersettings?userId=49542c9906ea49389e18f70434cffaaa&client=emby. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:42.465 Info Server: http/1.1 Response 200 to 192.168.1.1. Time: 0ms. http://192.168.1.5/emby/DisplayPreferences/usersettings?userId=49542c9906ea49389e18f70434cffaaa&client=emby 2021-04-28 10:15:42.517 Info Server: http/1.1 GET http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:42.518 Info Server: http/1.1 Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa 2021-04-28 10:15:42.540 Debug SessionManager: Creating new WebSocketController 2021-04-28 10:15:42.626 Info Server: http/1.1 POST http://192.168.1.5/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:42.630 Info Server: http/1.1 Response 204 to 192.168.1.1. Time: 4ms. http://192.168.1.5/emby/Sessions/Capabilities/Full 2021-04-28 10:15:42.844 Info Server: http/1.1 GET http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa/Views. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:42.846 Info Server: http/1.1 Response 200 to 192.168.1.1. Time: 1ms. http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa/Views 2021-04-28 10:15:42.860 Info Server: http/1.1 GET http://192.168.1.5/emby/LiveTv/Channels?userId=49542c9906ea49389e18f70434cffaaa&limit=1&ImageTypeLimit=1&EnableTotalRecordCount=false&EnableImages=false&EnableUserData=false. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:42.862 Info Server: http/1.1 Response 200 to 192.168.1.1. Time: 2ms. http://192.168.1.5/emby/LiveTv/Channels?userId=49542c9906ea49389e18f70434cffaaa&limit=1&ImageTypeLimit=1&EnableTotalRecordCount=false&EnableImages=false&EnableUserData=false 2021-04-28 10:15:43.029 Info Server: http/1.1 GET http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:43.032 Info Server: http/1.1 GET http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:43.036 Info Server: http/1.1 GET http://192.168.1.5/emby/LiveTv/Channels?userId=49542c9906ea49389e18f70434cffaaa&IsAiring=true&limit=24&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ProgramPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:43.040 Info Server: http/1.1 GET http://192.168.1.5/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=49542c9906ea49389e18f70434cffaaa&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:43.040 Info Server: http/1.1 GET http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=1c241e4923cbffc9a287aa091397147e. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:43.040 Info Server: http/1.1 Response 200 to 192.168.1.1. Time: 0ms. http://192.168.1.5/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=49542c9906ea49389e18f70434cffaaa&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false 2021-04-28 10:15:43.044 Info Server: http/1.1 GET http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=0b0ce896ea789cfb3d9e2013574421b0. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:43.048 Info Server: http/1.1 GET http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=d2d3741ea388ac67f2401cd5350ad1eb. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:43.048 Info Server: http/1.1 GET http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=c5e7eb27cf7d2b500e9eac8e08b771bb. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:43.052 Info Server: http/1.1 GET http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=b89f117566d8fd1d8a0457c1556a22bc. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:43.055 Info Server: http/1.1 GET http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=47b943143f89080a3ad7cdf748fd2d1f. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:43.055 Info Server: http/1.1 GET http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=7d403860c8555dea118c5a4ad0cfad73. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:43.059 Info Server: http/1.1 GET http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=d7d7cf53a1a2fdd3b826412b6b29c85e. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:43.063 Info Server: http/1.1 GET http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=28b5d5b8bef4bd1f1914503b5c11ac91. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager 2021-04-28 10:15:43.063 Debug SqliteItemRepository: Public GetItemLinks 2021-04-28 10:15:43.064 Debug SqliteItemRepository: Public GetItemLinks 2021-04-28 10:15:43.065 Debug SqliteItemRepository: Public GetItemLinks 2021-04-28 10:15:43.065 Info Server: http/1.1 Response 200 to 192.168.1.1. Time: 18ms. http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=c5e7eb27cf7d2b500e9eac8e08b771bb 2021-04-28 10:15:43.066 Info Server: http/1.1 GET http://192.168.1.5/emby/Users/49542c9906ea49389e18f70434cffaaa/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=06111092b812db9af48546ec2f41c3b1. UserAgent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.34 Safari/537.36 WebAppManager By the way there is the playback info from the tv 2021-04-28 10:23:27.093 Operating System: Linux version 4.15.0-142-generic (buildd@lgw01-amd64-036) (gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)) #146-Ubuntu SMP Tue Apr 13 01:11:19 UTC 20 OS/Process: x64/x64 Emby Server version: 4.6.0.40 Operating system: Unix 4.15.0.142 Command Line: /app/emby/EmbyServer.dll -programdata /config -ffdetect /app/emby/ffdetect -ffmpeg /app/emby/ffmpeg -ffprobe /app/emby/ffprobe -restartexitcode 3 App: Emby Theater 1.0.24 LG Smart TV (OLED65C9PLA) http://192.168.1.5/emby/videos/200123/hls1/main/0.ts?DeviceId=TW96aWxsYS81LjAgKFdlYjBTOyBMaW51eC9TbWFydFRWKSBBcHBsZVdlYktpdC81MzcuMzYgKEtIVE1MLCBsaWtlIEdlY2tvKSBDaHJvbWUvNTMuMC4yNzg1LjM0IFNhZmFyaS81MzcuMzYgV2ViQXBwTWFuYWdlcnwxNjE5MjU5MjEyMDcz&MediaSourceId=c8323c9697f1e3476186d008b2e7d9ea&PlaySessionId=d8c6e3c91dc543c2a644cf4af6dafa65&api_key=1d9b0a86bccf4ccf8f2e2194079e2b9d&VideoCodec=h264,h265,hevc&AudioCodec=ac3,eac3,aac,mp3&VideoBitrate=2552000&AudioBitrate=448000&AudioStreamIndex=1&TranscodingMaxAudioChannels=6&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=False&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&TranscodeReasons=ContainerBitrateExceedsLimit {"Protocol":"File","Id":"c8323c9697f1e3476186d008b2e7d9ea","Path":"/mnt/Cloud Storage/Cloud Storage Server 2/FR/Films4K[FR]/Zack Snyder's Justice League (2021)/Zack Snyder's Justice League (2021).mp4","Type":"Default","Container":"mp4","Size":35174710643,"Name":"Zack Snyder's Justice League","IsRemote":false,"RunTimeTicks":145281600000,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"hevc","CodecTag":"dvhe","Language":"eng","TimeBase":"1/24000","CodecTimeBase":"1001/24000","VideoRange":"SDR","DisplayTitle":"4K HEVC","DisplayLanguage":"English","IsInterlaced":false,"BitRate":17957031,"BitDepth":10,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":2160,"Width":3840,"AverageFrameRate":23.976025,"RealFrameRate":23.976025,"Profile":"Main 10","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p10le","Level":150,"IsAnamorphic":false},{"Codec":"eac3","CodecTag":"ec-3","Language":"fra","TimeBase":"1/48000","CodecTimeBase":"1/48000","DisplayTitle":"French EAC3 5.1 (Default)","DisplayLanguage":"French","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":640000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"},{"Codec":"eac3","CodecTag":"ec-3","Language":"eng","TimeBase":"1/48000","CodecTimeBase":"1/48000","DisplayTitle":"English EAC3 5.1 (Default)","DisplayLanguage":"English","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":768000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"},{"Codec":"mov_text","CodecTag":"tx3g","Language":"fra","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"French (Default MOV_TEXT)","DisplayLanguage":"French","IsInterlaced":false,"IsDefault":true,"IsForced":false,"Height":2160,"Width":3840,"Type":"Subtitle","Index":3,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"mov_text","CodecTag":"tx3g","Language":"fra","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"French (Default MOV_TEXT)","DisplayLanguage":"French","IsInterlaced":false,"BitRate":32,"IsDefault":true,"IsForced":false,"Height":2160,"Width":3840,"Type":"Subtitle","Index":4,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"mov_text","CodecTag":"tx3g","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"English (Default MOV_TEXT)","DisplayLanguage":"English","IsInterlaced":false,"BitRate":35,"IsDefault":true,"IsForced":false,"Height":2160,"Width":3840,"Type":"Subtitle","Index":5,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"}],"Formats":[],"Bitrate":19369120,"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false} >>>>>> User policy for Screamfox EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: False EnableAudioPlaybackTranscoding: True >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info Copy video stream >> False False Software Codec Info VideoInput >> False False Not a hardware decoder Info VideoOutput >> False False Not a hardware encoder Info Copy video stream >> False False Software Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format Size Next Info hevc >> - yuv420p10 yuv420p10 3840x2160 >> /app/emby/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-remux-01154af5-41ac-4eb9-8c77-ee20b80e17d9_1graph.txt" -copyts -start_at_zero -f mp4 -c:v:0 hevc -i "/mnt/Cloud Storage/Cloud Storage Server 2/FR/Films4K[FR]/Zack Snyder's Justice League (2021)/Zack Snyder's Justice League (2021).mp4" -map 0:0 -map 0:1 -sn -c:v:0 copy -c:a:0 ac3 -ab:a:0 384000 -ar:a:0 48000 -ac:a:0 6 -metadata:s:a:0 language=fre -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/config/transcoding-temp/A25873.m3u8" -segment_list_type m3u8 -segment_time 6 -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/config/transcoding-temp/A25873_%d.ts" 10:23:27.097 ffmpeg version 4.3.0-emby_2021_02_27 Copyright (c) 2000-2021 the FFmpeg developers and softworkz for Emby LLC 10:23:27.098 built with gcc 8.3.0 (crosstool-NG 1.24.0) 10:23:27.098 Execution Date: 2021-04-28 10:23:27 10:23:27.243 [hevc @ 0x15117c0] Skipping NAL unit 62 10:23:27.244 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/mnt/Cloud Storage/Cloud Storage Server 2/FR/Films4K[FR]/Zack Snyder's Justice League (2021)/Zack Snyder's Justice League (2021).mp4': 10:23:27.244 Metadata: 10:23:27.244 major_brand : isom 10:23:27.244 minor_version : 1 10:23:27.244 compatible_brands: isom 10:23:27.244 creation_time : 2021-03-18T21:28:28.000000Z 10:23:27.244 copyright : 10:23:27.244 copyright-eng : 10:23:27.244 Duration: 04:02:08.16, start: 0.000000, bitrate: 19369 kb/s 10:23:27.244 Stream #0:0(eng): Video: hevc (Main 10) (dvhe / 0x65687664), yuv420p10le(pc), 3840x2160 [SAR 1:1 DAR 16:9], 17957 kb/s, Level 150, 23.98 fps, 23.98 tbr, 24k tbn, 23.98 tbc (default) 10:23:27.244 Metadata: 10:23:27.244 creation_time : 2021-03-18T20:20:08.000000Z 10:23:27.244 handler_name : WEB 4K Dolby Vision MZABI (Thx) 10:23:27.244 encoder : DOVI Coding 10:23:27.244 Side data: 10:23:27.244 unknown side data type 29 (8 bytes) 10:23:27.244 Stream #0:1(fra): Audio: eac3 (ec-3 / 0x332D6365), 48000 Hz, 5.1(side), fltp, 640 kb/s (default) 10:23:27.244 Metadata: 10:23:27.244 handler_name : French (VFF) Dolby Digital Plus 5.1 @ 640 Kbps(Cut FrIeNdS) (Thx to LOST) 10:23:27.244 Side data: 10:23:27.244 audio service type: main 10:23:27.244 Stream #0:2(eng): Audio: eac3 (ec-3 / 0x332D6365), 48000 Hz, 5.1(side), fltp, 768 kb/s (default) 10:23:27.244 Metadata: 10:23:27.244 handler_name : English Dolby Digital Plus 5.1 with Dolby Atmos @ 768 Kbps 10:23:27.244 Side data: 10:23:27.244 audio service type: main 10:23:27.244 Stream #0:3(fra): Subtitle: mov_text (tx3g / 0x67337874), 3840x2160 (default) 10:23:27.244 Metadata: 10:23:27.244 creation_time : 2021-03-18T21:33:51.000000Z 10:23:27.244 handler_name : French Forced 10:23:27.244 Stream #0:4(fra): Subtitle: mov_text (tx3g / 0x67337874), 3840x2160, 0 kb/s (default) 10:23:27.244 Metadata: 10:23:27.244 creation_time : 2021-03-18T21:33:51.000000Z 10:23:27.244 handler_name : French 10:23:27.244 Stream #0:5(eng): Subtitle: mov_text (tx3g / 0x67337874), 3840x2160, 0 kb/s (default) 10:23:27.244 Metadata: 10:23:27.244 creation_time : 2021-03-18T21:33:51.000000Z 10:23:27.244 handler_name : Full English 10:23:27.244 Stream mapping: 10:23:27.244 Stream #0:0 -> #0:0 (copy) 10:23:27.244 Stream #0:1 -> #0:1 (eac3 (native) -> ac3 (native)) 10:23:27.244 Press [q] to stop, [?] for help 10:23:27.245 Output #0, segment, to '/config/transcoding-temp/A25873_%d.ts': 10:23:27.245 Metadata: 10:23:27.245 encoder : Lavf58.35.100 10:23:27.245 Stream #0:0: Video: hevc (Main 10) (dvhe / 0x65687664), yuv420p10le(pc), 3840x2160 [SAR 1:1 DAR 16:9], q=2-31, 17957 kb/s, Level 150, 23.98 fps, 23.98 tbr, 90k tbn, 23.98 tbc (default) 10:23:27.245 Side data: 10:23:27.245 unknown side data type 29 (8 bytes) 10:23:27.245 Stream #0:1(fre): Audio: ac3, 48000 Hz, 5.1, fltp, 384 kb/s (default) 10:23:27.245 Metadata: 10:23:27.245 encoder : Lavc58.62.100 ac3 10:23:27.245 Side data: 10:23:27.245 audio service type: main 10:23:27.245 [AVBSFContext @ 0x16648c0] No parameter sets in the extradata 10:23:27.327 [segment @ 0x152a680] Opening '/config/transcoding-temp/A25873.m3u8.tmp' for writing 10:23:27.327 SegmentComplete=video:0 Index=0 Start=0.000000 End=8.008000 Duration=8.008000 offset_pts=0 start_pts=0 Frames=192 filename=A25873_0.ts 10:23:27.327 [segment @ 0x152a680] Opening '/config/transcoding-temp/A25873_1.ts.tmp' for writing 10:23:27.354 [segment @ 0x152a680] Opening '/config/transcoding-temp/A25873.m3u8.tmp' for writing 10:23:27.355 SegmentComplete=video:0 Index=1 Start=8.008000 End=12.012000 Duration=4.004000 offset_pts=0 start_pts=8008000 Frames=96 filename=A25873_1.ts 10:23:27.355 [segment @ 0x152a680] Opening '/config/transcoding-temp/A25873_2.ts.tmp' for writing 10:23:27.420 [segment @ 0x152a680] Opening '/config/transcoding-temp/A25873.m3u8.tmp' for writing 10:23:27.420 SegmentComplete=video:0 Index=2 Start=12.012000 End=20.020000 Duration=8.008000 offset_pts=0 start_pts=12012000 Frames=192 filename=A25873_2.ts 10:23:27.420 [segment @ 0x152a680] Opening '/config/transcoding-temp/A25873_3.ts.tmp' for writing 10:23:27.465 [segment @ 0x152a680] Opening '/config/transcoding-temp/A25873.m3u8.tmp' for writing 10:23:27.466 SegmentComplete=video:0 Index=3 Start=20.020000 End=24.024000 Duration=4.004000 offset_pts=0 start_pts=20020000 Frames=96 filename=A25873_3.ts 10:23:27.466 [segment @ 0x152a680] Opening '/config/transcoding-temp/A25873_4.ts.tmp' for writing 10:23:27.559 [segment @ 0x152a680] Opening '/config/transcoding-temp/A25873.m3u8.tmp' for writing 10:23:27.559 SegmentComplete=video:0 Index=4 Start=24.024000 End=32.032000 Duration=8.008000 offset_pts=0 start_pts=24024000 Frames=192 filename=A25873_4.ts 10:23:27.559 [segment @ 0x152a680] Opening '/config/transcoding-temp/A25873_5.ts.tmp' for writing 10:23:27.603 [segment @ 0x152a680] Opening '/config/transcoding-temp/A25873.m3u8.tmp' for writing 10:23:27.603 SegmentComplete=video:0 Index=5 Start=32.032000 End=36.036000 Duration=4.004000 offset_pts=0 start_pts=32032000 Frames=96 filename=A25873_5.ts 10:23:27.603 [segment @ 0x152a680] Opening '/config/transcoding-temp/A25873_6.ts.tmp' for writing 10:23:27.696 [segment @ 0x152a680] Opening '/config/transcoding-temp/A25873.m3u8.tmp' for writing 10:23:27.697 SegmentComplete=video:0 Index=6 Start=36.036000 End=44.044000 Duration=8.008000 offset_pts=0 start_pts=36036000 Frames=192 filename=A25873_6.ts 10:23:27.697 [segment @ 0x152a680] Opening '/config/transcoding-temp/A25873_7.ts.tmp' for writing 10:23:27.737 [segment @ 0x152a680] Opening '/config/transcoding-temp/A25873.m3u8.tmp' for writing 10:23:27.737 SegmentComplete=video:0 Index=7 Start=44.044000 End=48.048000 Duration=4.004000 offset_pts=0 start_pts=44044000 Frames=96 filename=A25873_7.ts ... [q] command received. Exiting. 10:25:28.827 10:25:28.827 [segment @ 0x152a680] Opening '/config/transcoding-temp/A25873.m3u8.tmp' for writing 10:25:28.828 SegmentComplete=video:0 Index=533 Start=3199.196000 End=3207.204000 Duration=8.008000 offset_pts=0 start_pts=3199196000 Frames=192 filename=A25873_533.ts 10:25:28.828 frame=76896 fps=632 q=-1.0 Lsize= 7174616kB time=00:53:27.51 bitrate=18608.7kbits/s throttle=off speed= 26x 10:25:28.828 video:7024263kB audio:150352kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000000% Last message repeated 1 times 10:25:28.828 EXIT 10:25:28.829 ======= ExtraData 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 Edited April 28, 2021 by CyberPoison
SamES 1084 Posted April 28, 2021 Posted April 28, 2021 In that video it is DirectStreaming which is possibly an issue. Did you try this and turn the subs off before playback? 12 hours ago, SamES said: OK, thanks. Can you please try again in Emby on the details screen before you start playback, please turn off subtitles and make sure the first audio track is selected?
SamES 1084 Posted April 28, 2021 Posted April 28, 2021 It looks like you have 3Mbit limit set, either in the quality settings during playback, or on the server, but because you have disabled playback of transcoded video it is converting the audio. We really need to get this all back to ‘normal’ settings so that we can follow what’s going on. Please make sure any bitrate limits are turned off and quality is set to auto, then turn on all the user options to allow transcoding, conversions, etc, then try playback without any subtitles
CyberPoison 33 Posted April 28, 2021 Author Posted April 28, 2021 (edited) VID_20210428_124939.mp4 Edited April 28, 2021 by CyberPoison
CyberPoison 33 Posted April 28, 2021 Author Posted April 28, 2021 (edited) Yes it was a issue with the bitrate , thanks but there at normally disabling video transcode it should use the max video bitrate allowed right? There is a way to set all my users internet bitrate to maximum? By default? Edited April 28, 2021 by CyberPoison
SamES 1084 Posted April 28, 2021 Posted April 28, 2021 12 minutes ago, CyberPoison said: Yes it was a issue with the bitrate , thanks but there at normally disabling video transcode it should use the max video bitrate allowed right? Where did you have the bitrate set? Was that on the client in the Playback Quality settings? Because you still allow audio conversion it was converting audio, but as soon it changed from DirectPlay, I think this is where you issues start. You need to make sure this uses DirectPlay to work as you expect. Does that mean it is now DirectPlaying? Are the colors all good now? By default all users should be at maximum. Are all user on the local network, or are they remote?
CyberPoison 33 Posted April 28, 2021 Author Posted April 28, 2021 (edited) 9 minutes ago, SamES said: Where did you have the bitrate set? Was that on the client in the Playback Quality settings? Because you still allow audio conversion it was converting audio, but as soon it changed from DirectPlay, I think this is where you issues start. You need to make sure this uses DirectPlay to work as you expect. Does that mean it is now DirectPlaying? Are the colors all good now? By default all users should be at maximum. Are all user on the local network, or are they remote? It's from a hosted server, it was in auto in my playback on the TV btw i would like to set it to maximum by default instead of auto, can you tell me how to do that, in all users as bulk, if I disable video transcoding and audio its still green But as all users have the video transcode disabled and when they install emby on LG they can't set a diferent bitrate because it's locked as to auto in LG client playback. So let me try in auto as video and audio transcoding disabled. Doing it like this doesn't work as auto set in client lg playback and I was not able to change the max bitrate Edited April 28, 2021 by CyberPoison
SamES 1084 Posted April 28, 2021 Posted April 28, 2021 3 minutes ago, CyberPoison said: It's from a hosted server, it was in auto in my playback on the TV btw i would like to set it to maximum by default instead of auto, can you tell me how to do that, in all users as bulk, if I disable video transcoding and audio its still green Auto is maximum. What auto means is that it will do a quick bitrate speed test before playback, and it will only convert the video if it exceeds the maximum rate in the speed test. You can't set it to ignore this speed test. I don't think there is a bulk way to change the playback quality setting for all users, and it won't prevent users from changing it. Disabling these 3 options is probably the only way to prevent any transcoding (don't forget to press save at the bottom of the page). You will need to change this setting for each user, but it is not really a good idea as it may cause playback failures if the format is not supported or the network performance is not acceptable.
CyberPoison 33 Posted April 28, 2021 Author Posted April 28, 2021 (edited) Thanks many many thanks is it possible to change that settings with a sqlite editor? As it will be surely more quick And just to allow re encoding for live tv channels because i can't watch them on web browser they need a reencoding Edited April 28, 2021 by CyberPoison
SamES 1084 Posted April 28, 2021 Posted April 28, 2021 You know that on the server you can change these for each user fairly quickly. Otherwise, look in config/users on the server where Emby is installed. Each user folder has a policy.xml file with these settings. You must shutdown the server before changing these and I would recommend taking a backup first as you can easily make a mess. This is not a recommended way of making changes. To be honest, I think it is quicker to do this on the server in settings (tick three boxes and hit save) for each user than editing lots of text files and possibly making a mistake. 1
CyberPoison 33 Posted April 28, 2021 Author Posted April 28, 2021 (edited) and to allow reencoding for live tv channels only is there anything for them ? My point is to force 4K HDR / Dolby Vision to work without rencoding or transcoding. but allow FHD HD etc... to be rencoded Edited April 28, 2021 by CyberPoison
