Wengu 1 Posted March 3, 2021 Posted March 3, 2021 I've been using EMBY for a while now. Lately I've been having issues with my WAN access (external IP changes) and after that EMBY on my chromecast stops working. Whenever I try to connect using the PIN, it does nothing. I go to https://emby.media/pin, put in my info and pin, it says PIN accepted but the screen does not change. When I click next, it goes to the next screen but I can't connect unless I type in the server address manually (and then the user).
Solution ebr 16338 Posted March 3, 2021 Solution Posted March 3, 2021 Hi. It sounds like you may have removed the connection to your server. Please try removing the Connect email from the user and saving and then re-adding it. @cayars
Wengu 1 Posted March 3, 2021 Author Posted March 3, 2021 1 hour ago, ebr said: Hi. It sounds like you may have removed the connection to your server. Please try removing the Connect email from the user and saving and then re-adding it. @cayars That did the trick. Thank you! 1
