Indycars 2 Posted March 2, 2021 Posted March 2, 2021 (edited) I've been having a problem where I'm trying to watch live TV on CBS and PBS (All Channels are OTA), the progress wheel just goes around for ever. So I installed the latest firmware for my HDHomerun Quatro tuner. Now I can tune in CBS and PBS, but NBC and ABC are no longer available. Again the progress wheel never stops. I installed the HDHomerun app on another computer (Win10) and I can tune in over a dozen stations, including NBC and ABC. (didn't check all ~40 stations) Any ideas what could be wrong ??? Emby Theater Installed on Windows 7 Emby Server Version: 4.5.4 HDHomeRun CONNECT QUATRO Model: HDHR5-4US Device ID: 1070F049 Firmware: 20210224 . Edited March 3, 2021 by Indycars Grammer
Sammy 791 Posted March 2, 2021 Posted March 2, 2021 Beyond that, did you enter Guide Data and Refresh your guide?
Indycars 2 Posted March 2, 2021 Author Posted March 2, 2021 I go to Channels or to On Now, does not matter how I approach tuning in the channel. Refreshing the Guide does nothing. Below is my log file after letting the wheel spins for several minutes on ABC. embyserver.txt
Luke 42239 Posted March 3, 2021 Posted March 3, 2021 18 hours ago, Indycars said: I go to Channels or to On Now, does not matter how I approach tuning in the channel. Refreshing the Guide does nothing. Below is my log file after letting the wheel spins for several minutes on ABC. embyserver.txt 1.77 MB · 0 downloads Hi, please attach the ffmpeg log as well. thanks.
Indycars 2 Posted March 3, 2021 Author Posted March 3, 2021 Just before downloading the log files I tried to tune in Live TV Channel 4.1 KFOR-DT and the progress wheel just spin for about 3 minutes. I have attached both Emby Server and ffmpeg logs files this time. Appreciate the help ! embyserver(1).txt ffmpeg-transcode-0b9718de-19a1-4b98-9c96-debce5eddd0c_1.txt
Indycars 2 Posted March 8, 2021 Author Posted March 8, 2021 @Luke Did you find anything in those log files, I still need to get this fixed ???
Indycars 2 Posted March 9, 2021 Author Posted March 9, 2021 (edited) Doing some more troubleshooting, but I'm not sure what to think ! On one hand the HDHomeRun software cannot see the tuner, but I can access it thru it's IP address. I tried to run the Windows HDHomeRun program, but now it cannot find the tuner. I found their HDHomeRun Setup program and tried running that and got about the same results, see below. But I can still tune in some stations while in Emby Theater, but now I cannot tune in any of the 3 major networks. I can access the tuner by inputting the IP address. So I used that to tune in the 3 majors and then grab a screen shot of the status. Edited March 9, 2021 by Indycars
Luke 42239 Posted March 11, 2021 Posted March 11, 2021 Hi, have you resolved it in the Windows HDHomeRun program? I would suggest getting that squared away first. Please let us know if this helps. Thanks.
Solution Indycars 2 Posted March 13, 2021 Author Solution Posted March 13, 2021 (edited) It felt like I didn't get much help since it's been many days without a reply, but I'm guessing that the facts presented just didn't lead anyone to a next step. They sure didn't help me !!! The HDHomeRun Setup program is still a zero. But the HDHomeRun tuner program is picking up ALL the possible stations now .... see 2nd graphic below. HDHomeRun Tuner program is working great now, although I only used it for testing. Never used it for watching. It was solved by restarting the QNAP TS-451+ NAS that my Emby server resides on. QTS version: 4 . 4 . 3 . 1355 Thanks again for all the help ! Indy Edited March 13, 2021 by Indycars
Luke 42239 Posted March 23, 2021 Posted March 23, 2021 Hi there, glad to hear you resolved it. Thanks for following up !
