neik 874 Posted March 2, 2021 Posted March 2, 2021 Hi there, I've been playing with the Open Subtitles plugin and it works just fine (thanks for that) but I've still got a question: If I set it up to download subs automatically and there a many subs for a particular movie/episode how does it select the one it downloads at the end? Do the downloads count or the so called "trusted sources" on OpenSubtitles? Unfortunately, the KB doesn't provide information on this. Thank you!
GrimReaper 4828 Posted March 2, 2021 Posted March 2, 2021 21 minutes ago, neik said: Hi there, I've been playing with the Open Subtitles plugin and it works just fine (thanks for that) but I've still got a question: If I set it up to download subs automatically and there a many subs for a particular movie/episode how does it select the one it downloads at the end? Do the downloads count or the so called "trusted sources" on OpenSubtitles? Unfortunately, the KB doesn't provide information on this. Thank you! IIRC, order is Hash > Name > IMDB Id.
neik 874 Posted March 2, 2021 Author Posted March 2, 2021 I think we missunderstood each other, maybe my question wasn't precise enough. 1 hour ago, GrimReaper76 said: Hash > Name > IMDB Id. I guess, that's the way how a potential subtitles are identified but what happens next? The episode is matched and now there are 5 different subtitles matching the episode and language, which does the plugin pick?
GrimReaper 4828 Posted March 2, 2021 Posted March 2, 2021 (edited) 1 hour ago, neik said: I think we missunderstood each other, maybe my question wasn't precise enough. I guess, that's the way how a potential subtitles are identified but what happens next? The episode is matched and now there are 5 different subtitles matching the episode and language, which does the plugin pick? If any of them is a hash match - that one. If no, filename comparison next etc. If all are hash-match, then what difference does it make? Shouldn't they theoretically be the same? Edit: Or maybe I'm simply not understanding what you're asking? Edited March 2, 2021 by GrimReaper76 Append/Shorten
Luke 42154 Posted March 2, 2021 Posted March 2, 2021 The first one that comes back in the search results from the provider. 1
