kron0s 24 Posted March 2, 2021 Posted March 2, 2021 (edited) Before you ask me why don't I use Auto Aspect Ratio, the reason is because the video I'm watchin has black bars embedded into the video and with a 21:9 ultrawide, this makes it look like all 4 sides are surrounded by black bars. Before the latest update this was working, when I chose Cover usually, it would just zoom in the video. With the current update, the aspect ratio is wrong when I chose this option. See attached. Funny thing is when I click the settings button, the aspect ratio is temporarily "fixed" until the option pop up disappears, this is also attached. Issue is in both Chrome and Edge browsers, so I don't think it's browser specific. Auto Cover Cover with Settings "Clicked" Stretch Edited March 2, 2021 by kron0s
Luke 42240 Posted March 2, 2021 Posted March 2, 2021 Hi, cover will crop without altering the aspect ratio. Fill will stretch and may distort the video. Please let us know if this helps. Thanks.
kron0s 24 Posted March 2, 2021 Author Posted March 2, 2021 1 hour ago, Luke said: Hi, cover will crop without altering the aspect ratio. Fill will stretch and may distort the video. Please let us know if this helps. Thanks. I am reporting that cover is altering the aspect ratio. Please see the images I attached above.
Luke 42240 Posted March 2, 2021 Posted March 2, 2021 Ok, please attach the information requested in how to report a media playback issue. thanks.
kron0s 24 Posted March 2, 2021 Author Posted March 2, 2021 3 hours ago, Luke said: Ok, please attach the information requested in how to report a media playback issue. thanks. Are you saying, you just need the server logs in addition to the stuff I already posted above?
kron0s 24 Posted March 2, 2021 Author Posted March 2, 2021 (edited) 9 minutes ago, Luke said: Yes please, thanks. Ok see attached. Please note, that this only happens when the video is in "Full Screen" Mode (Square Icon button all to the way to the right of the buttons). When it's in "Windowed Mode" this behavior is not observed and everything is working as expected Please note, emby-logs.txt Edited March 2, 2021 by kron0s
kron0s 24 Posted March 3, 2021 Author Posted March 3, 2021 did some testing, seems like this behavior happens in chrome and edge, but looks good in firefox.
Luke 42240 Posted March 4, 2021 Posted March 4, 2021 In your log example it is direct playing so there might not be much we can do about this. We're relying on a function in the browser to handle the aspect ratio adjustment for us, and it's probably having difficulty with this specific video. I know it works just fine in my testing.
kron0s 24 Posted March 4, 2021 Author Posted March 4, 2021 10 minutes ago, Luke said: In your log example it is direct playing so there might not be much we can do about this. We're relying on a function in the browser to handle the aspect ratio adjustment for us, and it's probably having difficulty with this specific video. I know it works just fine in my testing. Yeah, slim to none on the browsers fixing this issue. I'll use Firefox as a workaround. Thanks.
kron0s 24 Posted May 11, 2023 Author Posted May 11, 2023 Did more research and figured this out this is a bug in Chrome and Edge - You can fix it by going into the flags and setting #use-angle to D3D9 and this will fix it. Another solution is to use " the "Ultrawidify" add-on. 2
lol 6 Posted May 24, 2023 Posted May 24, 2023 On 11/05/2023 at 15:41, kron0s said: Did more research and figured this out this is a bug in Chrome and Edge - You can fix it by going into the flags and setting #use-angle to D3D9 and this will fix it. Another solution is to use " the "Ultrawidify" add-on. Thank you! Your first suggestion has worked for me. 1 1
