quickmic 1709 Posted March 26, 2021 Posted March 26, 2021 On 3/25/2021 at 12:24 AM, parallaxview said: Is there a kanban board or anything? This functionality is pretty crucial to me. You can try the experimental version:
phunzie 42 Posted March 28, 2021 Author Posted March 28, 2021 Delete seems to be working fine in the experimental versions to remove item from library/database ...but it does require a manual "Update Library" to clear the item from being seen/listed in Kodi
BaukeZwart 94 Posted March 28, 2021 Posted March 28, 2021 It's working fine for me with the last experimental build without the need to update the library. Only thing needed to see the change in Kodi is exit the show list and open it again.
phunzie 42 Posted March 28, 2021 Author Posted March 28, 2021 (edited) ok, so i can also see the change if i exit the items list and return but decided to use the Keymap Editor add-on to map a key on my remote to Update Library...so after i delete an item, i press the remote button, and i'm good to go Edited March 28, 2021 by phunzie
