markdj 49 Posted February 27, 2021 Posted February 27, 2021 Am I the only one having issues with refreshing background artwork using Kodi 19 and Emby next gen? I refresh the artwork through Emby and while it does refresh poster art (for example) it does not refresh background artwork. All I get is a black screen then. Sometimes it takes about 30 minutes to disappear, sometimes longer I think. But it looks like Emby just disconnects or something because when I enter the add-on all options are gone (cache artwork, enter settings, reset database etc). Restarting Kodi fixes it most of the times but the artwork/backdrops still doesn’t come back then. Any ideas? (Running the screensaver does seem to refresh it)
markdj 49 Posted February 28, 2021 Author Posted February 28, 2021 Did a complete reinstall of Kodi and still the same. It happens after the Shield/Emby wakes from sleep. Some backgrounds work, others don’t load.
BaukeZwart 94 Posted March 16, 2021 Posted March 16, 2021 (edited) I also see this. Updating backdrops in Emby or tmm makes the background of the updated movie/series go blank in Kodi. Emby is self picks up the updated backdrop just fine. Using E4K next gen stable release. Edited March 16, 2021 by BaukeZwart
quickmic 1709 Posted March 17, 2021 Posted March 17, 2021 @markdj I reviewed your log. The issue is here: ERROR: EMBY.core.HTTP: Error -3 while decompressing data: incorrect header check This issue seems not directly related to the plugin, but I try to find a workaround. https://github.com/psf/requests/issues/5428 1
