donfrenchiano 1 Posted February 27, 2021 Posted February 27, 2021 I just updated to Kodi 19 and found out there is a new emby plugin. I'm on windows so i deleted my Kodi folder from AppData so on startup its like a fresh install. Everything is stock. I go to install Emby-Next-Gen from the repo and it installs but it will not open up. It says it fails and to check the log. Here is what my log says when i try to start it 2021-02-27 13:13:17.894 T:2856 INFO <general>: Python interpreter stopped 2021-02-27 13:13:55.145 T:5252 INFO <general>: initializing python engine. 2021-02-27 13:13:56.461 T:5252 ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <class 'ModuleNotFoundError'> Error Contents: No module named 'queue' Traceback (most recent call last): File "C:\Users\lr-htpc\AppData\Roaming\Kodi\addons\plugin.video.emby-next-gen\events.py", line 21, in <module> import core.artwork File "C:\Users\lr-htpc\AppData\Roaming\Kodi\addons\plugin.video.emby-next-gen\core\artwork.py", line 11, in <module> import requests File "C:\Users\lr-htpc\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\__init__.py", line 43, in <module> import urllib3 File "C:\Users\lr-htpc\AppData\Roaming\Kodi\addons\script.module.urllib3\lib\urllib3\__init__.py", line 7, in <module> from .connectionpool import HTTPConnectionPool, HTTPSConnectionPool, connection_from_url File "C:\Users\lr-htpc\AppData\Roaming\Kodi\addons\script.module.urllib3\lib\urllib3\connectionpool.py", line 28, in <module> from .packages.six.moves import queue File "C:\Users\lr-htpc\AppData\Roaming\Kodi\addons\script.module.urllib3\lib\urllib3\packages\six.py", line 91, in __get__ result = self._resolve() File "C:\Users\lr-htpc\AppData\Roaming\Kodi\addons\script.module.urllib3\lib\urllib3\packages\six.py", line 113, in _resolve return _import_module(self.mod) File "C:\Users\lr-htpc\AppData\Roaming\Kodi\addons\script.module.urllib3\lib\urllib3\packages\six.py", line 82, in _import_module __import__(name) ModuleNotFoundError: No module named 'queue' -->End of Python script error report<-- 2021-02-27 13:13:56.505 T:5252 INFO <general>: Python interpreter stopped 2021-02-27 13:17:28.381 T:8960 ERROR <general>: Control 55 in window 10025 has been asked to focus, but it can't 2021-02-27 13:17:28.404 T:6428 INFO <general>: initializing python engine. 2021-02-27 13:17:29.508 T:6428 ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <class 'ModuleNotFoundError'> Error Contents: No module named 'queue' Traceback (most recent call last): File "C:\Users\lr-htpc\AppData\Roaming\Kodi\addons\plugin.video.emby-next-gen\events.py", line 21, in <module> import core.artwork File "C:\Users\lr-htpc\AppData\Roaming\Kodi\addons\plugin.video.emby-next-gen\core\artwork.py", line 11, in <module> import requests File "C:\Users\lr-htpc\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\__init__.py", line 43, in <module> import urllib3 File "C:\Users\lr-htpc\AppData\Roaming\Kodi\addons\script.module.urllib3\lib\urllib3\__init__.py", line 7, in <module> from .connectionpool import HTTPConnectionPool, HTTPSConnectionPool, connection_from_url File "C:\Users\lr-htpc\AppData\Roaming\Kodi\addons\script.module.urllib3\lib\urllib3\connectionpool.py", line 28, in <module> from .packages.six.moves import queue File "C:\Users\lr-htpc\AppData\Roaming\Kodi\addons\script.module.urllib3\lib\urllib3\packages\six.py", line 91, in __get__ result = self._resolve() File "C:\Users\lr-htpc\AppData\Roaming\Kodi\addons\script.module.urllib3\lib\urllib3\packages\six.py", line 113, in _resolve return _import_module(self.mod) File "C:\Users\lr-htpc\AppData\Roaming\Kodi\addons\script.module.urllib3\lib\urllib3\packages\six.py", line 82, in _import_module __import__(name) ModuleNotFoundError: No module named 'queue' -->End of Python script error report<-- 2021-02-27 13:17:29.520 T:5452 INFO <general>: CActiveAESink::OpenSink - initialize sink 2021-02-27 13:17:29.564 T:6428 INFO <general>: Python interpreter stopped 2021-02-27 13:17:29.573 T:5664 ERROR <general>: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.emby-next-gen/ 2021-02-27 13:17:29.586 T:8960 ERROR <general>: CGUIMediaWindow::GetDirectory(plugin://plugin.video.emby-next-gen/) failed
quickmic 1709 Posted February 27, 2021 Posted February 27, 2021 I'll perform a test on Windows, actually this issue is not directly related to emby next-gen plugin. Looks like an issue of it's dependencies. "requests" loads "six" and that one crashed.
donfrenchiano 1 Posted February 27, 2021 Author Posted February 27, 2021 I don't know if this helps but I went back to 18.9 with a fresh install and installed emby-next-gen. This time it worked and it showed me all of the deps that it was going to install which it did not do on 19. Once it was installed and i made sure everything worked I upgraded to 19 and everything seems to be working. 1
wollabille 17 Posted February 28, 2021 Posted February 28, 2021 I have 2 Nvidia shields. When the first one was updated i had borrowed out my second one to my father in law because of the IPTV he wanted to try i also have installed there. On the one i had home i did get Next-Gen installed without any issues. This was a relief since i cant live without emby tbh Anyways, i got the second box home today and tried to install it, which failed horribly because it wouldn't install script.module.requests and script-module.datautil. I then tried to just copy both of these folders over from the working one. Which made one of them disappear. But the second one was still showing as needed to be installed. So in the end i tried to just copy the whole Kodi folder from working one to the non working and presto it worked. But why could i install it on one of them like 3 days ago and today i couldnt?
