D3lt4y 2 Posted February 27, 2021 Posted February 27, 2021 In my plugin I have successfully implemented Movie and Series Providers without any issues based on the examples from the Anime plugin. Now I am trying to do the same for people with no success. I have tried it first by implementing IRemoteMetadataProvider and when that didn't work I tested ILocalMetadataProvider also with no success. While debugging with breakpoints on the GetMetadata and GetSearchResults methods it seems like they are simply never called. Not while adding a person, not while manually refreshing the metadata and not while using the identify search. For reference these are my classes, stripped down to the minimum for testing: IRemoteMetadataProvider class MediaServerDBPersonProvider : IRemoteMetadataProvider<Person, PersonLookupInfo> { private readonly ILogger _log; private readonly IHttpClient _httpClient; private readonly IApplicationPaths _paths; private readonly IDirectoryService _directoryService; public static string provider_name = ProviderNames.MediaServerDB; public string Name => "MediaServerDB"; public MediaServerDBPersonProvider(IHttpClient httpClient, ILogger log, IDirectoryService directoryService, IApplicationPaths paths) { _httpClient = httpClient; _log = log; _directoryService = directoryService; _paths = paths; } public Task<MetadataResult<Person>> GetMetadata(PersonLookupInfo info, CancellationToken cancellationToken) { return Task.FromResult<MetadataResult<Person>>(new MetadataResult<Person>()); } public Task<IEnumerable<RemoteSearchResult>> GetSearchResults(PersonLookupInfo searchInfo, CancellationToken cancellationToken) { return Task.FromResult(Enumerable.Empty<RemoteSearchResult>()); } public Task<HttpResponseInfo> GetImageResponse(string url, CancellationToken cancellationToken) { return _httpClient.GetResponse(new HttpRequestOptions { CancellationToken = cancellationToken, Url = url }); } } ILocalMetadataProvider public class MediaServerDBLocalPersonProvider : ILocalMetadataProvider<Person> { private readonly ILogger _log; private readonly IApplicationPaths _paths; public static string provider_name = ProviderNames.MediaServerDB; public string Name => "MediaServerDB"; public MediaServerDBLocalPersonProvider(IApplicationPaths appPaths, ILogManager logManager) { _log = logManager.GetLogger(Name); _paths = appPaths; } public Task<MetadataResult<Person>> GetMetadata(ItemInfo info, IDirectoryService directoryService, CancellationToken cancellationToken) { return Task.FromResult<MetadataResult<Person>>(new MetadataResult<Person>()); } } One thing I noticed is that while for Movies and Series the used providers depend on the configuration of the library, the providers used for people seem to have a different configuration as even with all remote providers disabled in the library emby is still fetching remote metadata for people. So maybe I need to configure my provider to be used for people somehow? Any help would be appreciated. Thanks!
D3lt4y 2 Posted February 27, 2021 Author Posted February 27, 2021 Okay so after some more testing I managed to figure this out myself. The issue was the dependency injection of IDirectoryService. After removing it from the constructor the methods are called as expected. Seems like a bug to me. Or is there a good reason for IDirectoryService not to be supported for Person entities?
Luke 42255 Posted February 27, 2021 Posted February 27, 2021 Hi, we don't do searches for people by name except manually when using the identify feature, so i would test using that.
