gokuz 13 Posted February 25, 2021 Posted February 25, 2021 After testing with multiple clients/IPs on the same account. This setting defaults to AUTO every new login. How do I keep it at 4K-120Mbps forever permanently?
ebr 16309 Posted February 25, 2021 Posted February 25, 2021 Hi. You cannot do that because that setting is very dependent on the available connection for each of those devices. Related:
gokuz 13 Posted February 25, 2021 Author Posted February 25, 2021 1 hour ago, ebr said: Hi. You cannot do that because that setting is very dependent on the available connection for each of those devices. Related: I want to do this as the shared media are VERY small 200-500MB. RP4 doesn't bode well with transcoding. Basically no point in emby's client choosing to transcode if it "senses" my connection is weak.
ebr 16309 Posted February 25, 2021 Posted February 25, 2021 29 minutes ago, gokuz said: as the shared media are VERY small 200-500MB Hi. The size of the file isn't directly relevant. Rather it is the bitrate. And, if these are low-bitrate, then they shouldn't trigger transcoding (due to bitrate).
gokuz 13 Posted February 26, 2021 Author Posted February 26, 2021 13 hours ago, ebr said: Hi. The size of the file isn't directly relevant. Rather it is the bitrate. And, if these are low-bitrate, then they shouldn't trigger transcoding (due to bitrate). Fron my experience, emby doesnt detect "auto" very well. In weak signal areas, transcoding gets triggered. I manually have to change it to 4K in settings for it to play. The post you linked is 2 years ago, why not implement this feature?
ebr 16309 Posted February 26, 2021 Posted February 26, 2021 10 hours ago, gokuz said: In weak signal areas, transcoding gets triggered Hi. If the signal is weak, then the bitrate must be reduced in order for playback to continue properly. What else would you expect to happen?
gokuz 13 Posted February 27, 2021 Author Posted February 27, 2021 On 2/26/2021 at 11:27 PM, ebr said: Hi. If the signal is weak, then the bitrate must be reduced in order for playback to continue properly. What else would you expect to happen? Expect? What I expect is emby doing what I want it to. That's the whole point of having stuff self hosted. Back to the topic, the signal is weak but its good enough to play direct play when I manually set it to 4K 120. So emby's threshold for "weak signal" is bad. I can play it direct play no problems.
Luke 42204 Posted March 2, 2021 Posted March 2, 2021 Regarding settings storage, have your questions been answered related to that?
gokuz 13 Posted March 3, 2021 Author Posted March 3, 2021 5 hours ago, Luke said: Regarding settings storage, have your questions been answered related to that? Yes if you guys do not plan to implement this...
