lucasbuck 2 Posted February 24, 2021 Posted February 24, 2021 I'm trying to set either a password or pin code for my user account. Using Emby through WMC. I go under users, select my profile, then passwords. I give me an option to set a password, which I have and saved. Below that is Local Network Access. I've tried to with password and tried with a pin code I create. When I go through WMC to Emby it shows the profile as locked, but I've tried 'Require a password' and 'Allow a numeric pin code'. In both cases it says they are incorrect. What am I doing wrong? Thanks for any help.
Carlo 4561 Posted February 25, 2021 Posted February 25, 2021 Hi, what happens if you use the web console and set/change you password or PIN code this way?
lucasbuck 2 Posted February 25, 2021 Author Posted February 25, 2021 I am using the web console on the same machine as WMC. Its kind of weird, I thought it would be pretty straight forward.
Luke 42237 Posted February 25, 2021 Posted February 25, 2021 Hi, are you able to sign out of the web app and then sign back in with that username and password? What version of Emby for WMC are you using?
lucasbuck 2 Posted February 25, 2021 Author Posted February 25, 2021 I works on the web console logging in, but if you try to log in through WMC you get incorrect password. Server version is 4.5.4.0
lucasbuck 2 Posted February 25, 2021 Author Posted February 25, 2021 When I go to check for update for Emby for WMC it says its up to date. In WMC it says version 3.0.307.0
Solution ebr 16331 Posted February 25, 2021 Solution Posted February 25, 2021 10 hours ago, lucasbuck said: When I go to check for update for Emby for WMC it says its up to date. In WMC it says version 3.0.307.0 Hi. If you are using the current server version then you need to install the beta version of EMC. It isn't really that it is beta but, rather, that it is designed for the newer server. Please do that and let us know how it goes. Thanks.
lucasbuck 2 Posted February 26, 2021 Author Posted February 26, 2021 That worked! Thank you so much. 1
