Can not ues emby connect
9 minutes ago, cayars said:
If you only have one server just remove the other with the FORGET that prompts after you can't login to it.
If each VLAN is using different IP ranges the simple way would be to NETWORKS->Local IP address: in Emby to set the IP.  From that point on that will be the IP Emby will use.
In local network,I have only one IP address(192.168.x.x).but I have 4 Internet address.I have 4 vwans on my router.so can I bind one of vwans?if I can I will try to set Load balancing
Just setup a default in your in your router.
ok,thx
