Steveyal 0 Posted February 20, 2021 Posted February 20, 2021 HELP!! I can not get Emby for andoid TV to load on one of my devices. It is an A95X Max running android 8.1.0. I paid for the app through the playstore and even did a complete factory reset on the device....and Emby will not load. Crashes every time. The mobile version will load.
ebr 16338 Posted February 20, 2021 Posted February 20, 2021 Hi. If this device does not have the standard Android TV launcher, then you will need to be running the beta version of the app.
Steveyal 0 Posted February 20, 2021 Author Posted February 20, 2021 Great thank you. Where can I get that?
Steveyal 0 Posted February 20, 2021 Author Posted February 20, 2021 Thank you thank you thank you. I have no idea what I did...but it worked!! So, I assume I need to continue work the beta...forever or is there a point I can switch over to the public apk?
ebr 16338 Posted February 20, 2021 Posted February 20, 2021 8 minutes ago, Steveyal said: I need to continue work the beta...forever No. Once this beta is released, you can go back to using the release. Thanks.
