xnappo 1611 Posted August 23, 2014 Posted August 23, 2014 (edited) It really looks like a problem on the server/server config side to me. If you go here: http://10.1.1.115:8096/mediabrowser/Users/df3fadf92c79e676e63d71ab017ce576/items?ParentId=7e32077ec05ff41f97276393307b63d6&IsVirtualUnaired=false&IsMissing=False&Fields=EpisodeCount,SeasonCount,Path,Genres,Studios,CumulativeRunTimeTicks,MediaStreams,People,Overview&SortOrder=Ascending&SortBy=SortName&Genres= Do you see your TV shows? Can you browse TV fine through the web interface? xnappo [EDIT] @@Luke - seeing this in the returned error header. Any ideas? ('server', 'Mono-HTTPAPI/1.0'), ('x-application-error-code', 'Index and length must refer to a location within the string. Parameter name: length') Edited August 23, 2014 by xnappo
xnappo 1611 Posted August 23, 2014 Posted August 23, 2014 Good point. @@pstar , the MediaBrowser log is here: %appdata%\MediaBrowser-Server\logs That assumes you are running on Windows. xnappo
pstar 0 Posted August 23, 2014 Posted August 23, 2014 Hi guys. Server is set up with UNC paths. --PATH ("\\server\folder1\TV Shows") ----tv show title ----------Season 01 ------------------Episodes Under the server set up. I picked TV shows and added the paths for my TV shows. There are 8 paths in then library. Did the same for movies and music. From the web browser is all seems to work fine. No errors popping up. And can watch episodes after picking them from all TV shows. From the XBMB3C add-on only the "all TV shows" and "TV Shows" give the error loading the list. And can watch episodes from recently added and continuing. I'm not at home at the moment so I'll attach logs later. I haven't removed and re-added the TV library. I can give that a go.
pstar 0 Posted August 24, 2014 Posted August 24, 2014 Here is the log folder from media browser server :-) https://mega.co.nz/#!tpgGjLyL!ve-GSqTptoZrcoxAUUHrte3USCxSi79VIA_ZQi31oUk Haven't had time to remove and reinstall library today. thanks for taking the time to look into this for me.
xnappo 1611 Posted August 24, 2014 Posted August 24, 2014 Please try going to these two URLs from a web browser: http://10.1.1.115:8096/mediabrowser/Users/df3fadf92c79e676e63d71ab017ce576/items?ParentId=7e32077ec05ff41f97276393307b63d6&IsVirtualUnaired=false&IsMissing=False&Fields=EpisodeCount,SeasonCount,Path,Genres,Studios,CumulativeRunTimeTicks,MediaStreams,People,Overview&SortOrder=Ascending&SortBy=SortName&Genres= http://10.1.1.115:8096/mediabrowser/Users/df3fadf92c79e676e63d71ab017ce576/Items/b7c0e6941bfb7ee95ed39e1ba8363310 @@Luke, Please take a look at the server log file 'server-63544382541.txt' lines 18342 and 18687. Thanks, xnappo
Luke 42234 Posted August 24, 2014 Posted August 24, 2014 it will be resolved for the next server release.
xnappo 1611 Posted August 24, 2014 Posted August 24, 2014 Is there any work-around he can try? xnappo
Luke 42234 Posted August 24, 2014 Posted August 24, 2014 it looks like his series or episodes, or something, have bad or really long people names. so he can try cleaning them up. the fix will be to recover from the failure and continue on. 1
xnappo 1611 Posted August 24, 2014 Posted August 24, 2014 (edited) Thanks Luke. @@pstar - you can turn off 'People' in the XBMB3C Metadata settings - it isn't needed with most modified skins anymore anyway. xnappo Edited August 24, 2014 by xnappo 1
pstar 0 Posted August 25, 2014 Posted August 25, 2014 Hello Dev team I turned off "People" in the XBMB3C add-on and on the server and that got it to work. It did have a error a couple of times but allowed me to continue and browse through the TV shows via "TV Shows" and "All TV Shows" in the XBMB3C add-on. So all is good. Please try going to these two URLs from a web browser: http://10.1.1.115:8096/mediabrowser/Users/df3fadf92c79e676e63d71ab017ce576/items?ParentId=7e32077ec05ff41f97276393307b63d6&IsVirtualUnaired=false&IsMissing=False&Fields=EpisodeCount,SeasonCount,Path,Genres,Studios,CumulativeRunTimeTicks,MediaStreams,People,Overview&SortOrder=Ascending&SortBy=SortName&Genres= http://10.1.1.115:8096/mediabrowser/Users/df3fadf92c79e676e63d71ab017ce576/Items/b7c0e6941bfb7ee95ed39e1ba8363310 @@xnappo Your 1st link gave me this page https://mega.co.nz/#!wwRHVDZS!8a3zHFx97rFao6J0Exlsrlw_0Xj4FCBl3yvFQDnOglo the 2nd link https://mega.co.nz/#!0gBX3ZRL!mwAzZIobMa9-gminWr8Nve2LmM5GYkyXq_bXKJ1irh4 So Turning of the "people" option and the auto enter single season seem to fix things for me. Thanks for your help on this.
xnappo 1611 Posted August 25, 2014 Posted August 25, 2014 Okay - thanks. You should be able to turn 'auto enter' back on I think. xnappo
