lucasbuck 2 Posted February 18, 2021 Posted February 18, 2021 (edited) I'm trying to connect my laptop to my server which is on a desktop. My tablet and have no problems connecting at all. I've tried the IP for in home and remote access. They're on the same network, and I even shut off the laptops defender firewall briefly with no luck. Any ideas of what else I can try. Thanks for any help! Edited February 18, 2021 by lucasbuck
GrimReaper 4861 Posted February 18, 2021 Posted February 18, 2021 12 minutes ago, lucasbuck said: I'm trying to connect my laptop to my server which is on a desktop. My tablet and have no problems connecting at all. I've tried the IP for in home and remote access. They're on the same network, and I even shut off the laptops defender firewall briefly with no luck. Any ideas of what else I can try. Thanks for any help! Hi there. First, I suggest you edit your post and change the topic title to "Local" or "LAN" connection issue, as that might be more indicative of your issue - and consequently inform community in a more targeted way. "Remote" refers to WAN access, outside your network. Next, could you please describe with a little more detail (like your current setup and IPs) and how did you try to connect? 1
lucasbuck 2 Posted February 18, 2021 Author Posted February 18, 2021 Thanks, changed! The server is on the desktop computer (version 4.5.4.0). In the dashboard it says my server is up to date and the lan access says IP 192.168.200.2:8096 When I log into the emby site it gives me the option to add a server,. I enter the IP and it says connections failure.
GrimReaper 4861 Posted February 18, 2021 Posted February 18, 2021 2 minutes ago, lucasbuck said: Thanks, changed! The server is on the desktop computer (version 4.5.4.0). In the dashboard it says my server is up to date and the lan access says IP 192.168.200.2:8096 When I log into the emby site it gives me the option to add a server,. I enter the IP and it says connections failure. What do you mean by log into the Emby site?
GrimReaper 4861 Posted February 18, 2021 Posted February 18, 2021 (edited) IF I correctly understood your issue, you cannot access your server from a laptop in a same local network. Did you try typing 192.168.200.2:8096 into your laptop browser window? There's no servers to add, you'd already BE in your server. If you're trying to access your server through EmbyConnect (which is unnecessary for local access), you need to setup remote access (depending on your configuration, it might or might not require some additional steps). Did you do that? Edited February 18, 2021 by GrimReaper76 Typos
lucasbuck 2 Posted February 18, 2021 Author Posted February 18, 2021 Going to 192.168.200.2:8096 in the browser on the laptop just times out.
GrimReaper 4861 Posted February 18, 2021 Posted February 18, 2021 Just now, lucasbuck said: I went to http://app.emby.media Let's sort your local access first. Can you or can you not access your server locally?
GrimReaper 4861 Posted February 18, 2021 Posted February 18, 2021 Just now, lucasbuck said: Going to 192.168.200.2:8096 in the browser on the laptop just times out. Have you checked your firewall permissions on your server machine? Is your server allowed to accept incoming connections?
lucasbuck 2 Posted February 18, 2021 Author Posted February 18, 2021 I can access the sever with my tablet and phone using the Emby app.All the inbound Emby entries are green, and so is port 8096.
lucasbuck 2 Posted February 18, 2021 Author Posted February 18, 2021 No sure if it makes a difference, but my laptop has always been able to 'see' the media desktop, but not access any files (like to move or copy them, no permission). Never been able to fix that.
GrimReaper 4861 Posted February 18, 2021 Posted February 18, 2021 26 minutes ago, lucasbuck said: I can access the sever with my tablet and phone using the Emby app.All the inbound Emby entries are green, and so is port 8096. What's your laptop's IP address?
GrimReaper 4861 Posted February 18, 2021 Posted February 18, 2021 (edited) 15 minutes ago, lucasbuck said: 192.168.1.247 Well, you ain't on the same subnet as the server. Can you go to your server machine and type ipconfig into Command Prompt? Edit: Do you have multiple NIC in your system? Edited February 18, 2021 by GrimReaper76 Append
lucasbuck 2 Posted February 18, 2021 Author Posted February 18, 2021 198.168.200.2 is the desktop running the emby server. I know next to nothing about networking. I've got a router and 2 switches. That's all I know.
GrimReaper 4861 Posted February 18, 2021 Posted February 18, 2021 Just now, lucasbuck said: 198.168.200.2 is the desktop running the emby server. I know next to nothing about networking. I've got a router and 2 switches. That's all I know. We're trying to find out why is your server binding to that address, which is kinda unusual tbh, but step by step. On your server machine, type cmd into Search box; press Enter; type ipconfig; press Enter. Not complicated.
Carlo 4561 Posted February 18, 2021 Posted February 18, 2021 Hi, Sounds like you have two routers or APs using NAT and not just one. From your notebook open a cmd window and enter this. tracert 192.168.200.2 copy and paste those results here
lucasbuck 2 Posted February 18, 2021 Author Posted February 18, 2021 The desktop (emby server) is 192.168.200 . Here is the tracert from the laptop. It just keeps timing out: 1 1 ms 1 ms <1 ms router.asus.com [192.168.1.1] 2 11 ms 11 ms 12 ms 142.254.146.93 3 183 ms 22 ms 34 ms ae62.nwalinco01h.midwest.rr.com [74.128.4.25] 4 19 ms 17 ms 21 ms be29.lsvqkydb01r.midwest.rr.com [65.29.27.154] 5 * * * Request timed out. 6 * * * Request timed out. 7 * * * Request timed out. 8 * * * Request timed out. 9 * * * Request timed out. 10 * * * Request timed out. 11 * * * Request timed out.
Carlo 4561 Posted February 18, 2021 Posted February 18, 2021 (edited) Is that a typo or did you type 192.128.200.2 ? If you did get the 2 in there correctly then you're going out to the internet vs your network. What equipment do you have in the way or routers, Access Points and switches between the Internet and your Server? Same question from Internet to your Notebook? EDIT: do you have a VPN client running anywhere? Edited February 18, 2021 by cayars
Happy2Play 9802 Posted February 18, 2021 Posted February 18, 2021 Something does not add up but I can assume if you added 192.168.0.0/16 to Dashboard-Networks "LAN networks:", does it work?
lucasbuck 2 Posted February 18, 2021 Author Posted February 18, 2021 It was a typo, I meant 192.168.200.2 No VPN. Asus router and switches. The server machine is hooked to a switch. Not sure what was meant by adding anything in the dashboard.
Happy2Play 9802 Posted February 18, 2021 Posted February 18, 2021 But how would this client get that IP address? Your router gateway is 192.168.1.1, so all you clients should be in that same subnet.
lucasbuck 2 Posted February 18, 2021 Author Posted February 18, 2021 Okay, it was jumping from router, to switch, to another switch. I connected it directly to the router and the ip changes to 192.168.1.194 and I can connect from the laptop. But I can't leave it like this.
Happy2Play 9802 Posted February 18, 2021 Posted February 18, 2021 (edited) 6 minutes ago, lucasbuck said: Okay, it was jumping from router, to switch, to another switch. I connected it directly to the router and the ip changes to 192.168.1.194 and I can connect from the laptop. But I can't leave it like this. That is why I said this. But you can list your networks also. I am guessing that 192.168.200.x subnet is not considered local. 25 minutes ago, Happy2Play said: Something does not add up but I can assume if you added 192.168.0.0/16 to Dashboard-Networks "LAN networks:", does it work? Edited February 18, 2021 by Happy2Play
lucasbuck 2 Posted February 18, 2021 Author Posted February 18, 2021 I put it back the way it was and it held the 192.168.1.194.8086 ip, so I guess it's fixed.
