psykix 97 Posted August 11, 2014 Posted August 11, 2014 I have several albums with warning triangles. They have cover art, they are identified and have a musicbrainz id which when clicked takes me to the correct album on Musicbrainz. The artists is recognised. So how do I find out what the problem is to eliminate the triangles? It would be great if the warning triangle would give you a bit more of an indication of what the issue is. This is one example :-
