zachattack83 3 Posted February 16, 2021 Posted February 16, 2021 So, what alternatives are as easy to use as schedules direct for setting up my tv guide? It seemed to be the only one that wanted to work for me, and now they say I'm not allowed to use it for some license violation or something...
rbjtech 5341 Posted February 16, 2021 Posted February 16, 2021 Are you not using 'Emby Guide Data' ? I'm reasonably sure that emby moved away from Schedules Direct some time ago - so it may just be a case of setting up the new Guide Provider in the live tv setup. 1
zachattack83 3 Posted February 16, 2021 Author Posted February 16, 2021 I just went through the set up for emby guide data. When I set up Schedules Direct is was late 2019 or early 2020. It was the only one that I could get to work. Looks like the EGD is set up and working. Is there a way to remove certain channels? I seem to have a lot of blank ones.
rbjtech 5341 Posted February 16, 2021 Posted February 16, 2021 Yep - in map channels, you can delete them. 1
zachattack83 3 Posted February 16, 2021 Author Posted February 16, 2021 where is the remove option? Its only letting my select another channel to map it to?
zachattack83 3 Posted February 16, 2021 Author Posted February 16, 2021 Actually went into the HDHR and set all the working channels to 'favorite', then I readded the HDHR to emby and only imported the favorite channels. 1
BlueSnake 4 Posted March 16, 2021 Posted March 16, 2021 I today received a mail from Schedules direct that they will block Emby starting from June 1 2021. In germany I only can select SD and xmlTV. So when will Emby Guide Data be available in Germany? Or do I really have to switch to Plex in order to get working epg data?
ebr 16331 Posted March 16, 2021 Posted March 16, 2021 4 hours ago, BlueSnake said: I today received a mail from Schedules direct that they will block Emby starting from June 1 2021. In germany I only can select SD and xmlTV. So when will Emby Guide Data be available in Germany? Or do I really have to switch to Plex in order to get working epg data? Hi. In the meantime, you can try this:
BlueSnake 4 Posted March 16, 2021 Posted March 16, 2021 Thank you for your reply, but epg123 is running on a pc, correct? I have emby running on my Synology NAS, so I don't want to run a PC just for EPG. So this is no solution for me.
ebr 16331 Posted March 16, 2021 Posted March 16, 2021 Hi. While I don't know specifics, I do believe there are Linux-based options.
Carlo 4561 Posted March 17, 2021 Posted March 17, 2021 Here is a list of other guide providers that can be used as well if you have this need. https://support.emby.media/support/solutions/articles/44002149110-other-sources-of-epg-guide-data
BlueSnake 4 Posted March 18, 2021 Posted March 18, 2021 Thanks, I will switch to epg.best in the future. But nevertheless I hope that Emby guide data will be available in germany as well. 1
BlueSnake 4 Posted October 31, 2023 Posted October 31, 2023 Any updates regarding Emby Guide Data in germany?
ebr 16331 Posted October 31, 2023 Posted October 31, 2023 2 hours ago, BlueSnake said: Any updates regarding Emby Guide Data in germany? Hi. No updates at this time.
