moha85 4 Posted February 15, 2021 Posted February 15, 2021 Hi all I have a couple of problems with 2 addons, I don't know if this has been opened or not but I can't find anything about it, it may be too noob XD The first is when I download Auto Box Sets plugins from the panel catalog, the log tells me that it is installed but I do not get anything in my accessories to make it work. The second is with Auto Movie Version Grouping, I have put it in /var/lib/emby/plugins, it appears in my plugins but it does nothing. Can you help me with this? Greetings
Happy2Play 9814 Posted February 15, 2021 Posted February 15, 2021 53 minutes ago, moha85 said: The first is when I download Auto Box Sets plugins from the panel catalog, the log tells me that it is installed but I do not get anything in my accessories to make it work. The plugin is now obsolete in beta server. It is built into the server now. There is a per library option. https://emby.media/community/index.php?/topic/94475-46020-rework-collections-storage/ 54 minutes ago, moha85 said: The second is with Auto Movie Version Grouping, I have put it in /var/lib/emby/plugins, it appears in my plugins but it does nothing. This has been brought up in the plugin topic. It is a matter of whether the plugin dev will update the plugin for this beta or wait. Automatic version grouping for movies - Plugins - Emby Community 1
ebr 16346 Posted February 16, 2021 Posted February 16, 2021 Hi. If you are going to run beta versions of the server, you should keep up with the information in the testing forum here. Thanks.
moha85 4 Posted February 16, 2021 Author Posted February 16, 2021 Thaks for all 5 hours ago, ebr said: Hi. If you are going to run beta versions of the server, you should keep up with the information in the testing forum here. Thanks. Sorry iam are a noob, in all this, but I will be attentive as much as possible to everything in the forum Thx
ebr 16346 Posted February 17, 2021 Posted February 17, 2021 18 hours ago, moha85 said: Thaks for all Sorry iam are a noob, in all this, but I will be attentive as much as possible to everything in the forum Thx You may want to consider running the stable releases only then as beta will undoubtedly cause you problems. However, you need to wait until the current beta goes stable as we don't support going back in versions. Thanks.
