boblmarl 2 Posted February 14, 2021 Posted February 14, 2021 Fire TV stuck at the sign in with connect. I am at emby.media/pin and pin has been confirmed. Unfortunately nothing happens on the fire tv. Uninstalled and reinstalled twice. The first screenshot has a different user and pass (for testing purposes) and still did not work.
ebr 16336 Posted February 14, 2021 Posted February 14, 2021 Hi. Did you press "Next" after confirming the PIN.
boblmarl 2 Posted February 15, 2021 Author Posted February 15, 2021 (edited) Yes, tried several times. The next screen was log out of emby connect and choose server. Choose server had no servers to choose from. Edited February 15, 2021 by boblmarl
ebr 16336 Posted February 15, 2021 Posted February 15, 2021 Did you successfully connect your ID to a server? It sounds like it wasn't - or that server was removed. Try re-connecting it. Emby Connect
boblmarl 2 Posted February 15, 2021 Author Posted February 15, 2021 I shared my Amazon account so my parents could try Amazon before they became a member. I deregistered their FireTV stick when they became a member and then reregistered it using the new Amazon account. When I fired up Emby there was an error saying something like you don't have permission. I then uninstalled, reinstalled and then couldn't get past the PIN screen. I might have to reset the device to get it to work. Thanks for your time.
ebr 16336 Posted February 15, 2021 Posted February 15, 2021 But you have gotten past the PIN screen. Didn't you just say above that it goes to a server screen but there are no servers? This would just indicate that there are no servers connected to the Emby Connect ID you used to confirm the PIN.
boblmarl 2 Posted February 16, 2021 Author Posted February 16, 2021 (edited) When I hit next on this Fire TV. However, the same servers are available on my phone, other computers, other Fire TVs, etc. Edited February 16, 2021 by boblmarl
ebr 16336 Posted February 17, 2021 Posted February 17, 2021 47 minutes ago, boblmarl said: the same servers are available on my phone, other computers, other Fire TVs Each app remembers servers it has connected to in the past. Did you try my suggestion above - or try just entering the address manually?
boblmarl 2 Posted March 7, 2021 Author Posted March 7, 2021 For some odd reason it worked its self out. I guess I just needed to be patient.
ODRAWDE 0 Posted September 13, 2025 Posted September 13, 2025 All I get is enter address manually or sign out tried pressing on get server no response
Luke 42243 Posted September 13, 2025 Posted September 13, 2025 2 hours ago, ODRAWDE said: All I get is enter address manually or sign out tried pressing on get server no response Hi, did you try entering the address manually?
