MarchandMiel 0 Posted February 14, 2021 Posted February 14, 2021 When in play a Dolby SoundCheck (Dolby_Leaf_Lossless_ATMOS-thedigitaltheater.mkv) directly with VLC (with the passthrough parameter activated) on my computer, I can hear the sound moving thru all my speakers (9.1 setup) AND the INFO menu from the Marantz SR6011 display "Dolby Atmos/TrueHD" Input Signal. This way to play this Demo obtain a perfect sound result. But, when I play the same SoundCheck in a Microsoft Edge Web Browser (v 88.0.705.68 64 bits), thru a Emby interface, my SR6011 INFO menu displays "PCM" Input Signal and Surround mode. The result is that I only hear the sound with the front speakers in stereo. The Emby Info Menu display that this demo is played with DirectStream in HTTP/HLS and the Direct Stream Info is H.264 (direct) and MP3 codecs. So it seams that the transcoding process killed the "Dolby Atmos/TrueHD" sound. As I always use Emby to watch movies and music, could you tell me : 1) Is it a bug or a feature not yet offered in Emby ? 2) If so, is there an other way to use a Passthrough parameter in Emby to hear the original Atmos sound or any other tricks ? Thanks,
Solution Luke 42204 Posted February 14, 2021 Solution Posted February 14, 2021 Hi, web browsers do not supports Dolby Atmos/TrueHD, so that audio will always need to be converted. On Windows I would suggest trying our Emby Theater app: https://emby.media/emby-theater.html
