khaled988 1 Posted February 11, 2021 Posted February 11, 2021 Hello How are you doing .? There is a problem logging in From the link: http://app.emby.media Is there a solution to the problem?
Abobader 3485 Posted February 11, 2021 Posted February 11, 2021 Hello khaled988, Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
pwhodges 2028 Posted February 11, 2021 Posted February 11, 2021 Have you been through the support page about connecting to your server, both locally and externally? https://support.emby.media/support/solutions/articles/44001849007-connectivity Paul
khaled988 1 Posted February 11, 2021 Author Posted February 11, 2021 1 minute ago, pwhodges said: Have you been through the support page about connecting to your server, both locally and externally? https://support.emby.media/support/solutions/articles/44001849007-connectivity Paul How to install a domain?
Carlo 4561 Posted February 11, 2021 Posted February 11, 2021 https://www.pcmag.com/news/how-to-register-a-domain-name-for-your-website Hi, that article on PCMag will get you started with the basics of purchasing a domain name. Almost all domain providers also run DNS servers that you can use as well. So once you have the domain name you want you would use their DNS system to point a record such as "emby".yourdomain.ext to your WAN IP address. You will want to refer to instructions for DNS setup on the providers pages as they are all a bit different.
Happy2Play 9802 Posted February 11, 2021 Posted February 11, 2021 What is the actual issue? That is the new pop up required to redirect to your server. As there were media takedown requests sent to emby.media and Emby does not provide content. And if you have a domain you would never need to use app.emby.media either, but if you did you would just redirect the same way.
