ocdmonkey 0 Posted February 9, 2021 Posted February 9, 2021 (edited) I've been trying to figure this out for a while, but no matter what I do a ton of my albums either have blank or incomplete album art. Even when I manually change the album art it keeps reverting back to these glitched versions after a while (and appear this way no matter what device I'm viewing from). I've tried manually deleting the images from the folders and then manually changing them in the web interface, but they still keep reverting. It would also be great if I could avoid changing these manually in the first place, since I have a lot of albums. The images it saves in the folders are typically corrupted the exact same way. I've included a screenshot which shows several albums with incomplete album art (along with ones with missing album art which strikes me as weird considering no other program I've used has had a problem fetching the artwork for several of them, and in at least one case it refused to use the embedded album art from the files). I also have had no problems with TV shows or movies like this, really this is the only major problem I've had with emby so far. Edited February 9, 2021 by ocdmonkey formatting issue
Baenwort 119 Posted February 10, 2021 Posted February 10, 2021 Which version are you running? Emby recently overhauled how music is IDed to move from a folder based to a tag based system.
ocdmonkey 0 Posted February 10, 2021 Author Posted February 10, 2021 I'm running 4.5.4.0 according to the server dashboard. I installed it on my TrueNAS Core machine if that's relevant.
Luke 42238 Posted February 10, 2021 Posted February 10, 2021 Hi, yes this has all been reworked for the upcoming 4.6 release and I think will perform better with that once available. Thanks.
ocdmonkey 0 Posted February 10, 2021 Author Posted February 10, 2021 Well that's good to hear. Any idea when that version will be released?
