aarpat 1 Posted February 15, 2021 Author Posted February 15, 2021 (edited) I plugged in an ethernet cord, and that seems to have fixed the playback issue. It seems like it's (at least partially) a networking issue, so I'll test out moving to another channel or to 2.4 ghz. If there's no wireless workaround, I can run the wire permanently; but I'd like to avoid that. Do you think it also might be a failure to transcode issue? Is an i5-4570T with 8 gb of ram adequate to handle transcoding? Thanks, everyone. Edit: As another data point, I tested my ipad near my router. I received 240 mbps down, but still had issues playing the 1080p-16Mbps file. That makes me think something else is going on. Although, for what it's worth, the ipad also shows up as 192.168.1.1 in the logs. It must be some networking oddity with the linksys router. Edited February 15, 2021 by aarpat
Carlo 4561 Posted February 15, 2021 Posted February 15, 2021 230Mb in itself doesn't really tell you a lot. Example, should it have been 400Mb but you're getting lost packets? It's not really an indication of quality.
pwhodges 2028 Posted February 15, 2021 Posted February 15, 2021 Another possibility is that you are getting interference which is corrupting the wifi data. If you are close to a neighbour's router, for instance, or a bluetooth printer, even a microwave. Changing band could well change the parameters of this enough to resolve the issue. Paul
rbjtech 5337 Posted February 16, 2021 Posted February 16, 2021 22 hours ago, aarpat said: Edit: As another data point, I tested my ipad near my router. I received 240 mbps down, but still had issues playing the 1080p-16Mbps file. That makes me think something else is going on. Although, for what it's worth, the ipad also shows up as 192.168.1.1 in the logs. It must be some networking oddity with the linksys router. What is the model number of the linksys ? Most modern routers/WAP's these days do actually isolate the wireless networks through some form of firewall/packet inspection/filtering even through they technically sit on the same LAN (aka micro segmentation). There may be some options on the router/AP to remove the 'intelligence' for the emby source IP - allowing full speed to the wireless clients.
aarpat 1 Posted February 17, 2021 Author Posted February 17, 2021 (edited) On 2/15/2021 at 2:18 PM, cayars said: 230Mb in itself doesn't really tell you a lot. Example, should it have been 400Mb but you're getting lost packets? It's not really an indication of quality. That's pretty close to my max download speed from the ISP, so I thought it would helpful. On 2/15/2021 at 3:00 PM, pwhodges said: Another possibility is that you are getting interference which is corrupting the wifi data. If you are close to a neighbour's router, for instance, or a bluetooth printer, even a microwave. Changing band could well change the parameters of this enough to resolve the issue. Paul I live in a larger building with multiple wifis. I tested a few different channels, and it didn't seem to help. Oddly, switching to 2.4 ghz seemed to allow playback without any issues. 11 hours ago, rbjtech said: What is the model number of the linksys ? Most modern routers/WAP's these days do actually isolate the wireless networks through some form of firewall/packet inspection/filtering even through they technically sit on the same LAN (aka micro segmentation). There may be some options on the router/AP to remove the 'intelligence' for the emby source IP - allowing full speed to the wireless clients. Linksys model EA7400. I quickly looked through the settings and did not notice anything about that. But let me know if you see something I should change. Thanks. Edited February 17, 2021 by aarpat
Solution rbjtech 5337 Posted February 17, 2021 Solution Posted February 17, 2021 7 hours ago, aarpat said: I live in a larger building with multiple wifis. I tested a few different channels, and it didn't seem to help. Oddly, switching to 2.4 ghz seemed to allow playback without any issues. This is a big clue to your issues. 2.4Ghz is technically 'slower' than 5Ghz but it has much more 'range' - if it works on 2.4, then it's just a matter of fixing 5Ghz or sticking with 2.4 On your phone, I would download a 'wifi finder' type app (I use Ubiquiti WiFiman as it's free and a great app) - and see what other devices are using the 5Ghz signal - and then change channel to one that is free and no overlaps if possible. Do not use DFS channels unless absolutely necessary. Looking at the manual for your router - it also has some advanced wifi-features that may be worth setting on/off. Airtime Fairness - Boosts overall network speed by reducing traffic jams caused by slower devices.Dynamic Frequency Selection (DFS) - If enabled, your router will use 5 GHz channels that are shared with radar. When radar is using a channel, the router must switch and might lose Wi-Fi. Another limitation of DFS is that the older devices cannot use it and will be limited to the router’s 2.4 GHz band when it is on a DFS channel.Client Steering - Directs your wireless devices to the router / node with the strongest signal.Node Steering - Allow your routers / nodes to always connect to the router / node with the strongest signal. If you move a router / node or one goes offline, any connected routers / nodes will self-heal by connecting to the strongest signal available
Luke 42203 Posted March 1, 2021 Posted March 1, 2021 Hi, has this advice resolved your issue? Are you still running into this?
aarpat 1 Posted March 5, 2021 Author Posted March 5, 2021 Sorry for not updating the post. Switching to 2.4 ghz seems to have done the trick for now. I'll let you know if the problem reoccurs. Thanks everyone for the help.
