fraggelnostalgi 0 Posted February 7, 2021 Posted February 7, 2021 I get 10+ second pauses every 5-10 seconds playing 1080p video using a Beebox i5-7200U with 16gb of ram to a LG 65 C7. The video is 7.5Mbps according to the LG Emby app stats Orbi mesh network reports about 500+ Mbps on both the Beebox and LG Everything has line of sight Beebox is reporting 3% CPU usage, 37% free memory Beebox sends 2Mbps over the network for a few seconds, then stops for 10-20 seconds Web based network bandwidth testing comes in at 120Mbps both ways I disabled subtitles (made no difference) I disabled hardware acceleration (made no difference) I limited the threads to 2 (made no difference) I changed the encoding preset to veryfast and increased the CRF to 26 (made no difference) What else can I try?
Solution fraggelnostalgi 0 Posted February 7, 2021 Author Solution Posted February 7, 2021 (edited) Damnit, I just noticed that the TV has a browser and web based bandwidth testing on it reports 1.5Mbps... weirdly, Netflix works with no issue and so does YouTube 4K videos (and mesh network monitor still reports 500+ on the TV wireless). Is LG throttling select apps? EDIT: Found a page saying that LG TVs from 2017 don’t like 5ghz channels above 50 (DFS?) but mine was set to 36, so still open for suggestions. SOLUTION: Pulling the power on the TV and restarting it fixed it... for now. Edited February 7, 2021 by fraggelnostalgi
Luke 42204 Posted February 7, 2021 Posted February 7, 2021 Hi, glad to hear you've resolved it. Thanks for following up.
