suchamoneypit 0 Posted February 7, 2021 Posted February 7, 2021 (edited) How do you make your libraries not show up on a Samsung smart TV? I only have one user, they are set to not be remembered, not show on local network, and require a password on LAN - yet on my new Samsung TV Emby shows up and if you open it, it immediately gives a screen showing all my libraries. What is the point of restricting libraries to users and restricting view on LAN and then it blasts every library with zero authentication required on the TV by default on LAN? I've gone through the settings screen and turned on like every privacy feature there is for the user and it still shows everything on the TV with no authentication required. You launch Emby and are immediately staring right at my media. Am I missing something? How do I make this content now show up to everyone with zero authentication? Help appreciated. I am running Emby on the latest version on a Unraid docker. Edited February 7, 2021 by suchamoneypit
Abobader 3485 Posted February 7, 2021 Posted February 7, 2021 Hello suchamoneypit, Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Solution Happy2Play 9802 Posted February 7, 2021 Solution Posted February 7, 2021 Are you talking about DLNA or a specific Emby app on the TV? If DLNA then you need to disable the DLNA server. Dashboard-DLNA
ebr 16309 Posted February 7, 2021 Posted February 7, 2021 Or choose the proper user in the drop-down for DLNA to use.
suchamoneypit 0 Posted February 8, 2021 Author Posted February 8, 2021 (edited) Thank you for the help! That's what it was. I turned off DLNA and its no longer showing up. I did not know what DLNA was. Edited February 8, 2021 by suchamoneypit
