JeremyR 11 Posted February 7, 2021 Posted February 7, 2021 I have a HDHomeRun Duo, two tuners. I have it attached to my server and everything works except actual receipt of a channel. I can get tuned but I stops and stutters and artifacts. I thought this was making sure my antenna was set up correctly. Recently I worked on that and even with a close-by station I get the same issue. HOWEVER when I use the HDHomeRun viewer It is clear and fine. All three local networks through the HDHR viewer are fine. I have the HDHR on encode to mobile for a smaller stream and the Emby server allowing that. any ideas?
ebr 16337 Posted February 7, 2021 Posted February 7, 2021 Hi. Can we please look at a specific example?
