quntmglfr 0 Posted February 6, 2021 Posted February 6, 2021 When using Emby Theater to DirectPlay a video with multiple audio tracks the DTS tracks work normally but the AC3 tracks do not correspond to their listed name. For example I have files with 5 audio tracks if I choose the first AC3 audio track I get no audio: = No Audio But if I select the "French AC3 stereo" it outputs the "English AC3 stereo" audio: = English AC3 stereo I tried downloading the file via Emby Theater and playing it but it still has the same issue. If I play the files directly with other video players (VLC, MPC-HC) the track selection aligns properly and they all output the correct audio. server_log.txt
Luke 42239 Posted February 10, 2021 Posted February 10, 2021 Hi, that's strange, haven't seen this before. Can you provide a sample video for testing?
quntmglfr 0 Posted September 6, 2021 Author Posted September 6, 2021 Sorry I dropped the ball on this one. I have attached a sample of a video that has this issue. I also confirmed that it is still happening using the clip I supplied as well as with my other multi-audio track videos. Star Trek s01e01 - Enhanced_edit.mkv
Carlo 4561 Posted September 6, 2021 Posted September 6, 2021 Hi, have you tested with the latest version to confirm this is still an issue? What version of Theater are you currently using?
Guest Posted September 6, 2021 Posted September 6, 2021 (edited) On 2/10/2021 at 9:35 AM, Luke said: Hi, that's strange, haven't seen this before. Can you provide a sample video for testing? Yes you have, it's pretty much the same as I already reported. The audio track selection is pretty much broken. Edited September 7, 2021 by generiq
Luke 42239 Posted September 7, 2021 Posted September 7, 2021 HI, yes we're looking into it. Thanks for reporting.
quntmglfr 0 Posted September 9, 2021 Author Posted September 9, 2021 Thanks, I am currently running Emby Server Version 4.6.4.0 and Emby for Windows 1.1.365.0
