Luke 42237 Posted March 13, 2021 Posted March 13, 2021 @Vitz please let us know if this helps. thanks.
Vitz 1 Posted March 19, 2021 Author Posted March 19, 2021 (edited) On 13/03/2021 at 19:00, Luke said: @Vitz please let us know if this helps. thanks. Unfortunately, no. Manually deleting the ffmpeg pkg and reinstalling emby-server only resulted Emby complaining about there not being any compatible streams whenever I tried playing a video. I tried installing the beta, which gave me the same problem. Finally, I did pkg delete -a and this just nuked the jail. Even snapshots can't bring it back now so I guess I'll have to start from scratch and hopefully import the database to a new jail. Edit: I managed to revive the jail from a snapshot made earlier this week, but I'm not going to mess with it again. I guess I'll just have to live with it and hope this gets fixed at some point through an update from the community plugin. I might mess about with a new jail entirely and see if I can clone the existing database there but I'm not touching the current jail again. Edited March 19, 2021 by Vitz
Luke 42237 Posted April 1, 2021 Posted April 1, 2021 On 3/19/2021 at 12:07 PM, Vitz said: Unfortunately, no. Manually deleting the ffmpeg pkg and reinstalling emby-server only resulted Emby complaining about there not being any compatible streams whenever I tried playing a video. I tried installing the beta, which gave me the same problem. Finally, I did pkg delete -a and this just nuked the jail. Even snapshots can't bring it back now so I guess I'll have to start from scratch and hopefully import the database to a new jail. Edit: I managed to revive the jail from a snapshot made earlier this week, but I'm not going to mess with it again. I guess I'll just have to live with it and hope this gets fixed at some point through an update from the community plugin. I might mess about with a new jail entirely and see if I can clone the existing database there but I'm not touching the current jail again. @Vitz when you say re0installing emby server, how were you trying to do that? Were you using one of our supported install methods for FreeBSD/FreeNAS ? https://emby.media/download
Vitz 1 Posted May 29, 2021 Author Posted May 29, 2021 On 01/04/2021 at 08:23, Luke said: @Vitz when you say re0installing emby server, how were you trying to do that? Were you using one of our supported install methods for FreeBSD/FreeNAS ? https://emby.media/download Apologies for the radio silence. Yes, I tried the FreeBSD install methods described on the page you linked to. At this point I don't require further help as I will be switching to a Proxmox setup and will no longer be running Emby through the FreeNAS plugin. I'll be happy to answer any remaining questions you may have, though.
