sjkiss 28 Posted February 5, 2021 Posted February 5, 2021 Has anyone used Emby with any Garmin GPS watches? Specifically, I'd like to know if it's possible to download (sync) music from an Emby server to a Garmin GPS watch.
Luke 42233 Posted February 6, 2021 Posted February 6, 2021 Hi, it's not currently possible but something to consider for future updates. thanks.
matticas 3 Posted September 3, 2025 Posted September 3, 2025 Hi there, sorry to revive an old topic - just chiming in to see if anyone else made progress with this? I have found "SubMusic for Plex" which is some app you can install on your garmin watch, and it sync's playlists from a plex sever. I think the biggest difficulty is getting it into the Garmin Connect IQ store? Did anyone else find another solution? The Garmin Express windows program is garbage for sync'ing music. It works, but horrid to use, and zero sync features, just add/remove from device from a file list in a folder.
jachin99 88 Posted September 12, 2025 Posted September 12, 2025 I just got a Garmin, and it would be nice to see an emby app 1
