Snargo 0 Posted February 2, 2021 Posted February 2, 2021 I run Emby 4.5.4.0 on Portainer on an OMV server. I have been recreating the container for various reasons but now I cannot watch some shows that I had watched in the past on the same setup and hardware. It seems like a codec issue and I dont know how to resolve that. I will go to play the show and I get the following error. Then I will keep getting the error for the number of shows in the folder. Seems like it tries each one. Movies play fine and some Shows play fine. I havent been able to nail down what types of shows or codec it is not liking. Playback Error No compatible streams are currently available. Please try again later or contact your system administrator for details. How can I fix this issue because I know I had watched some of these shows previously? Thanks. ffmpeg-transcode-311ad536-6581-449c-b5e9-fdbeb0db6f20_1.txt ffmpeg-transcode-098c4147-fe33-4ec4-9ef5-1576ffd50207_1.txt embyserver.txt
Luke 42246 Posted February 2, 2021 Posted February 2, 2021 Quote 13:32:12.210 /data/tvshows/Island hunters/Island.Hunters.S04E14.Hunting.for.Georgian.Bay.Views.XviD-AFG.avi: Invalid data found when processing input Hi, where is your media stored? Is something wrong with the file?
Snargo 0 Posted February 3, 2021 Author Posted February 3, 2021 7 hours ago, Luke said: Hi, where is your media stored? Is something wrong with the file? The file is stored on an external drive. This one was actually an Avi file which those have never played on my Emby server and I never try to put those on the server. Attached is another log from a similar file in the same folder that is mkv I have never had trouble with mkv files before now and every movie mkv I have tried works on this server. The movie files are stored on the same external drive just another folder. basically some video files work some do not on the same share on the same external drive I am using. ffmpeg-transcode-72e0f95d-9072-4f65-ad1e-c4a682c13e76_1.txt
