jasonmcroy 320 Posted March 2, 2021 Posted March 2, 2021 Well, all I know on the tester end - it ain't showin' up ya'll.
Solution redlozenge 1 Posted March 9, 2021 Solution Posted March 9, 2021 I know this isn't ideal, but I solved the issue with the Channels DVR XMLTV listings by making a little python script to parse the "onscreen" field and create an "xmltv_ns" field which Emby will recognize. I scheduled it in cron to run a couple times a day, and I point Emby to this new XML instead. #!/usr/bin/env python3 import requests URL = "http://192.168.1.6:8089/devices/TVE-Suddenlink/guide/xmltv?duration=604800" tve_xml = requests.get(URL) xmlOutput = "/var/www/html/xmltv/xmltv_ns.xml" with open(xmlOutput,"w", encoding="utf8") as fileOut: for line in tve_xml.text.splitlines(): fileOut.write(line+"\n") if '<episode-num system="onscreen">' in line: season_episode = line.replace('<episode-num system="onscreen">','').replace('</episode-num>','') if "S" in season_episode: season = ((season_episode.split('S'))[1].split('E'))[0] episode = ((season_episode.split('S'))[1].split('E'))[1] fileOut.write(' <episode-num system="xmltv_ns">' + str(int(season)-1) + '.' + str(int(episode)-1) + '.</episode-num>\n') 1
nyplayer 90 Posted March 12, 2021 Author Posted March 12, 2021 On 3/9/2021 at 7:57 AM, redlozenge said: I know this isn't ideal, but I solved the issue with the Channels DVR XMLTV listings by making a little python script to parse the "onscreen" field and create an "xmltv_ns" field which Emby will recognize. I scheduled it in cron to run a couple times a day, and I point Emby to this new XML instead. #!/usr/bin/env python3 import requests URL = "http://192.168.1.6:8089/devices/TVE-Suddenlink/guide/xmltv?duration=604800" tve_xml = requests.get(URL) xmlOutput = "/var/www/html/xmltv/xmltv_ns.xml" with open(xmlOutput,"w", encoding="utf8") as fileOut: for line in tve_xml.text.splitlines(): fileOut.write(line+"\n") if '<episode-num system="onscreen">' in line: season_episode = line.replace('<episode-num system="onscreen">','').replace('</episode-num>','') if "S" in season_episode: season = ((season_episode.split('S'))[1].split('E'))[0] episode = ((season_episode.split('S'))[1].split('E'))[1] fileOut.write(' <episode-num system="xmltv_ns">' + str(int(season)-1) + '.' + str(int(episode)-1) + '.</episode-num>\n') Great job with this but I have given any hope of seeing this implemented ... I feel that this will go the way of adding EDL support ... I will just use channels dvr.
Carlo 4561 Posted March 12, 2021 Posted March 12, 2021 6 minutes ago, nyplayer said: Great job with this but I have given any hope of seeing this implemented ... I feel that this will go the way of adding EDL support ... I will just use channels dvr. What do you mean?
nyplayer 90 Posted May 1, 2021 Author Posted May 1, 2021 @redlozenge Thanks that helped a lot much appreciated.
nyplayer 90 Posted November 23, 2021 Author Posted November 23, 2021 This has been fixed in the latest Pre-Release of XML from Channels DVR. 1
Luke 42243 Posted November 26, 2021 Posted November 26, 2021 On 11/23/2021 at 12:13 PM, nyplayer said: This has been fixed in the latest Pre-Release of XML from Channels DVR. What exactly did they change?
Carlo 4561 Posted November 26, 2021 Posted November 26, 2021 The incompatible XML names used by them.
nyplayer 90 Posted December 2, 2021 Author Posted December 2, 2021 (edited) On 11/25/2021 at 7:10 PM, Luke said: What exactly did they change? This appears to have been added to XML ... Also Silicondust added it to their XML <episode-num system="xmltv_ns">24.55.</episode-num> Edited December 2, 2021 by nyplayer
Luke 42243 Posted December 2, 2021 Posted December 2, 2021 13 hours ago, nyplayer said: This appears to have been added to XML ... Also Silicondust added it to their XML <episode-num system="xmltv_ns">24.55.</episode-num> That's great, thanks for the info.
