gokuz 13 Posted February 1, 2021 Posted February 1, 2021 (edited) Show A = JPN + Eng Sub Show B = ENG + NoSubs Both shows have individual separate files Edited February 1, 2021 by gokuz
Solution gokuz 13 Posted February 1, 2021 Author Solution Posted February 1, 2021 (edited) Fixed, used another tvshow.nfo. Edited February 1, 2021 by gokuz
gokuz 13 Posted February 1, 2021 Author Posted February 1, 2021 7 minutes ago, Luke said: Thanks for the feedback. Didn't want to create another thread, I have another query. What sort of nfo do I need to have for "Seasons" Overview. For Tvshow, its tvshow.nfo. I want to have separate nfo for Season 1, Season 2, Season 3, etc. For Overview only. It can be edited normally through emby but I want it in nfo form. i.e. Season 1 Overview. What sort of .nfo file does it take for emby to detect this?
Luke 42204 Posted February 1, 2021 Posted February 1, 2021 I would try just enabling emby to save the season nfo, then click save in the metadata editor and then you'll have an example file.
gokuz 13 Posted February 1, 2021 Author Posted February 1, 2021 27 minutes ago, Luke said: I would try just enabling emby to save the season nfo, then click save in the metadata editor and then you'll have an example file. Don't you know the exact naming convention for season's nfo? It would mess everything up if I save metadata locally, overwrite my current one. Please find this out for me.
PenkethBoy 2068 Posted February 1, 2021 Posted February 1, 2021 or just do a test on one folder which you have backed up prior to testing
gokuz 13 Posted February 1, 2021 Author Posted February 1, 2021 6 minutes ago, PenkethBoy said: or just do a test on one folder which you have backed up prior to testing where is the location for it? the newly created .nfo
PenkethBoy 2068 Posted February 1, 2021 Posted February 1, 2021 wild stab in the dark but i would guess in the season folder!
gokuz 13 Posted February 1, 2021 Author Posted February 1, 2021 1 minute ago, PenkethBoy said: wild stab in the dark but i would guess in the season folder! No its not. What name does it use?
PenkethBoy 2068 Posted February 1, 2021 Posted February 1, 2021 sounds like you have not enabled nfo saving on the library drum role...... season.nfo
gokuz 13 Posted February 1, 2021 Author Posted February 1, 2021 did a test for season.nfo, it worked. Put this in your wiki for other people's future reference. <season> <plot>here it is</plot> </season> 1
gokuz 13 Posted February 1, 2021 Author Posted February 1, 2021 1 minute ago, PenkethBoy said: sounds like you have not enabled nfo saving on the library drum role...... season.nfo You should have said earlier. Don't make people do experiments when you know the answer. Don't beat around the bush next time. 1
PenkethBoy 2068 Posted February 1, 2021 Posted February 1, 2021 Why - you did not read what Luke posted well enough and you have now learnt something - the onus is on you to do the work not me 1
PenkethBoy 2068 Posted February 1, 2021 Posted February 1, 2021 4 minutes ago, gokuz said: did a test for season.nfo, it worked. Put this in your wiki for other people's future reference. <season> <plot>here it is</plot> </season> if you had searched for this sort of info in the foums it has come up before
gokuz 13 Posted February 1, 2021 Author Posted February 1, 2021 1 minute ago, PenkethBoy said: Why - you did not read what Luke posted well enough and you have now learnt something - the onus is on you to do the work not me I don't see you or luke saying "seasons.nfo". That was what I asked originally. I have no problems doing tests if you guys don't know the answers, but that's not the case. Oh well, thanks anyway.
gokuz 13 Posted February 1, 2021 Author Posted February 1, 2021 1 minute ago, PenkethBoy said: if you had searched for this sort of info in the foums it has come up before Where? As far as my search skills are concerned this is new info. Where did you find this info?
gokuz 13 Posted February 1, 2021 Author Posted February 1, 2021 1 minute ago, PenkethBoy said: see ya That's what I thought.
