abel880209 0 Posted January 31, 2021 Posted January 31, 2021 buenas como puedo hacer para que mi servidor emby reprodusca un trailer local guardado en mi pc antes de cada pelicula saludos
Carlo 4561 Posted January 31, 2021 Posted January 31, 2021 Hi, Check out the cinema into plugin available in the catalog for premiere license holders. It can do exactly this.
abel880209 0 Posted February 1, 2021 Author Posted February 1, 2021 ya instale el plugin cinema intro, lo configure para que busque en una carpeta que cree parqa los trailer pero no me lso reproduce los como podria darme un ejemplo de como debo ponerlos para que mi servidor los detecte como trailer saludos
Happy2Play 9802 Posted February 1, 2021 Posted February 1, 2021 ¿Puedes mostrar una captura de pantalla de la configuración de Cinema Intros? ¿Se guardan sus remolques con medios? ¿O está intentando agregar una biblioteca de avances? ¿Cómo se llaman sus remolques? Can you show a screenshot of your Cinema Intros settings. Are your trailers saved with media? Or are you trying to add a trailers library? How are your Trailers named?
abel880209 0 Posted February 4, 2021 Author Posted February 4, 2021 siento no poder responder antes con este problema de la covid la coneccion en cuba esta inestable yo cree una carpeta para los trailer y le di la direccion y tambien copie los trailer a la carpeta de las peliculas dodne esta cada una pero nada a beses me salia un trailer que no tenia que ver con esa pelicula no se que estoy haciendo mal si pudiera decirme lo que debo hacer saludos
Luke 42204 Posted February 6, 2021 Posted February 6, 2021 On 2/3/2021 at 8:23 PM, abel880209 said: I'm sorry I can't answer before with this covid problem, the connection in Cuba is unstable, I created a folder for the trailers and gave it the address and I also copied the trailers to the folder for the movies, where each one is but nothing to kiss me came out a trailer that had nothing to do with that movie I don't know what I'm doing wrong if you could tell me what to do, greetings Hi there, can you please show us how you created your files and folders for the trailers?
abel880209 0 Posted February 7, 2021 Author Posted February 7, 2021 lo hice de dos formas cree una carpeta que se llama trailer en la que puse los trailer con el nombre de la pelicula ejemplo ¡Vaya patrulla! (2014) - Trailer.mp4 y tambien copie ese trailer en la carpeta de peliculas en la carpeta de esa pelicula pero nada si pudiera decirme como es que debo hacerlo o como debo renombrar el trailer se lo agradecere alomejor estoy haciendo algo mal saludos
Happy2Play 9802 Posted February 7, 2021 Posted February 7, 2021 (edited) 53 minutes ago, abel880209 said: I did it in two ways create a folder called trailer in which I put the trailers with the name of the movie example Wow patrol! (2014) - Trailer.mp4 and also copy that trailer into the movie folder in that movie folder but nothing if you could tell me how to do it or how I should rename the trailer I'll thank you maybe I'm doing something wrong greetings Emby Trailers : Emby Trailers can be in a Movie subfolder called "trailers" not "trailer" and named however you like or in movie folder named moviename-trailer.ext (no spaces). Edited February 7, 2021 by Happy2Play 1
