denywinarto 5 Posted January 31, 2021 Posted January 31, 2021 I still dont understand how it works if i want to open the link via WAN. Assuming i have this file on my library Z:\Movies\A\Alien (2004)\Alien (2004).mkv So i put Alien (2004).strm, containing http://ddnsname:8096/Movies/A/Alien (2004)/Alien (2004).mkv ran media scan open it on other pc via WAN connection, but it says unable to find specified file. What am i missing?
Luke 42204 Posted January 31, 2021 Posted January 31, 2021 Quote open it on other pc via WAN connection Hi, how exactly did you do this?
denywinarto 5 Posted January 31, 2021 Author Posted January 31, 2021 (edited) 1 hour ago, Luke said: Hi, how exactly did you do this? http://ddnsname:8096/Movies/A/Alien (2004)/Alien (2004).mkv Using the address i specified in .strm file Edited January 31, 2021 by denywinarto
crusher11 1134 Posted January 31, 2021 Posted January 31, 2021 What's your goal? What do you think strm files are for?
denywinarto 5 Posted January 31, 2021 Author Posted January 31, 2021 1 hour ago, crusher11 said: What's your goal? What do you think strm files are for? To stream a specific movie from external network, maybe i misunderstood something?
crusher11 1134 Posted January 31, 2021 Posted January 31, 2021 A strm file gets added to your library just like a video file, and is accessed the same way. It can contain the URL of media that isn't on the server.
denywinarto 5 Posted January 31, 2021 Author Posted January 31, 2021 32 minutes ago, crusher11 said: A strm file gets added to your library just like a video file, and is accessed the same way. It can contain the URL of media that isn't on the server. Hmm odd i'm not seeing that .strm file when i browse emby from external network. Anyways, i just want to share a movie about coronavirus to a family from different city, am i right about using this?
crusher11 1134 Posted January 31, 2021 Posted January 31, 2021 Why do you need a STRM file to do that? Emby can do that on its own; give them an account on your server.
Happy2Play 9802 Posted January 31, 2021 Posted January 31, 2021 (edited) 11 hours ago, denywinarto said: To stream a specific movie from external network, maybe i misunderstood something? The only way giving a strm file will work is if it has a proper url. This "http://ddnsname:8096/Movies/A/Alien (2004)/Alien (2004).mkv" will never work, as Emby does not sent a url like that nor would anyone like that. Why not log into Emby and just select play? Edited January 31, 2021 by Happy2Play 1
denywinarto 5 Posted February 1, 2021 Author Posted February 1, 2021 3 hours ago, Happy2Play said: The only way giving a strm file will work is if it has a proper url. This "http://ddnsname:8096/Movies/A/Alien (2004)/Alien (2004).mkv" will never work, as Emby does not sent a url like that nor would anyone like that. Why not log into Emby and just select play? The people i'm sharing with are elderly people who are not tech-savy and more likely to watch youtube hoaxes, you see. So i need something that is easier to access, preferably click and play. Login to emby and searching for the correct movie might be too complicated for them
Happy2Play 9802 Posted February 1, 2021 Posted February 1, 2021 (edited) There might be a way to build the url in Emby's API but this is beyond me. Api link at the bottom of the Dashboard. Edited February 1, 2021 by Happy2Play
rbjtech 5337 Posted February 1, 2021 Posted February 1, 2021 (edited) If they are only interested in a few files, then the easiest way to do this is to is to deny everything in 'Parental Settings' for their account - and just Tag the files you want them to see. In the example below - anything with the Tag of '4K' will be able to be seen/played - but obviously you can name it whatever you wish .. Edited February 1, 2021 by rbjtech 1
denywinarto 5 Posted February 1, 2021 Author Posted February 1, 2021 14 hours ago, Happy2Play said: There might be a way to build the url in Emby's API but this is beyond me. Api link at the bottom of the Dashboard. Care to elaborate? I've found the api list but i dont know which one to use 16 minutes ago, rbjtech said: If they are only interested in a few files, then the easiest way to do this is to is to deny everything in 'Parental Settings' for their account - and just Tag the files you want them to see. This is almost ideal but it still needs to login, i suppose there's no way to bypass login?
rbjtech 5337 Posted February 1, 2021 Posted February 1, 2021 8 minutes ago, denywinarto said: This is almost ideal but it still needs to login, i suppose there's no way to bypass login? They/you only need to login once - then whenever they open the client, it auto logs in next time so they can direct play the media from the main screen if they wish.
Carlo 4561 Posted February 1, 2021 Posted February 1, 2021 Just to make something clear if not already. STRM files are for the SERVER itself to find the location of files to add to a library. It's just a placehold pointing to the actual location of the media file. STRM files are NOT used by users in any manner directly. 1
denywinarto 5 Posted February 2, 2021 Author Posted February 2, 2021 20 hours ago, rbjtech said: They/you only need to login once - then whenever they open the client, it auto logs in next time so they can direct play the media from the main screen if they wish. So there's absolutely no way to click and play? I'm sharing with 2 dozens of people 18 hours ago, cayars said: Just to make something clear if not already. STRM files are for the SERVER itself to find the location of files to add to a library. It's just a placehold pointing to the actual location of the media file. STRM files are NOT used by users in any manner directly. Thanks for clarifying.
