cbauer25 5 Posted January 31, 2021 Posted January 31, 2021 Ever since the update in late December I have had issues with movies freezing. Common denominator seems to be a DTS track. Is there a known issue or fix?
cbauer25 5 Posted January 31, 2021 Author Posted January 31, 2021 Did some experimenting...happening to most movies, not just DTS. Added log files. ffmpeg-transcode-13bb5134-41cb-4f25-8863-520ba427988a_1.txt
Luke 42204 Posted February 1, 2021 Posted February 1, 2021 Hi, is this only happening on videos with vc1 video?
Luke 42204 Posted February 2, 2021 Posted February 2, 2021 14 minutes ago, cbauer25 said: No, have examples of H264 as well. Can we look at a log example of that? Thanks.
cbauer25 5 Posted February 3, 2021 Author Posted February 3, 2021 Sorry for the delay...here you go. embyserver.txt ffmpeg-transcode-206c6871-a4e1-4078-97c9-02e491ee4325_1.txt
ebr 16310 Posted February 3, 2021 Posted February 3, 2021 Hi. That item is not transcoding due to the audio. It is transcoding due to its bitrate - which is over what the app is telling it it can handle. It is transcoding plenty fast enough but maybe there are other constraints that mean this bitrate is still too high. Is this a remote connection? Can you try setting the max bitrate in the app to 10Mb and see if that solves the problem?
cbauer25 5 Posted February 3, 2021 Author Posted February 3, 2021 I am running multiple FireTVs and all are having the issue. Set the bitrate to 10MB and still froze. Not aware of any recent changes I've made. Logs attached. Thanks! ffmpeg-transcode-8f37545b-297e-4a45-9c40-585d40afd978_1 (1).txt ffmpeg-transcode-986c9e69-fb3e-4745-b167-9fb862be1694_1 (1).txt embyserver (2).txt
Carlo 4561 Posted February 4, 2021 Posted February 4, 2021 Both ffmpeg logs show transcoding being fast enough so that's not the reason. How are these clients connected to the server? Home network or remote? Wifi or Ethernet?
Carlo 4561 Posted February 4, 2021 Posted February 4, 2021 Have you sent an in app log yet? This might be the next step if not done already.
Carlo 4561 Posted February 4, 2021 Posted February 4, 2021 1 hour ago, cbauer25 said: Just sent the app logs Can you give the time you sent them and the user logged in? @ebr
cbauer25 5 Posted February 4, 2021 Author Posted February 4, 2021 User is bauerfamily...guessing around 7 pm central 1
ebr 16310 Posted February 4, 2021 Posted February 4, 2021 10 hours ago, cbauer25 said: User is bauerfamily...guessing around 7 pm central Hi. There was no playback in your log. Did you create the issue and then back immediately to the app home screen and send the log?
cbauer25 5 Posted February 4, 2021 Author Posted February 4, 2021 Thought so yes. But I can redo. Will have to wait until this evening.
ebr 16310 Posted February 4, 2021 Posted February 4, 2021 Make sure you play only long enough for the issue to occur. Thanks.
cbauer25 5 Posted February 5, 2021 Author Posted February 5, 2021 Ok just tried to resend logs at 7pm central
ebr 16310 Posted February 5, 2021 Posted February 5, 2021 14 hours ago, cbauer25 said: Ok just tried to resend logs at 7pm central I don't see any obvious issues in that log but the item was streaming at over 20Mb/s. I thought we were testing at lower bitrates. Can you try setting the app to 5Mb and see if it plays smoothly then? If it does, move it up until you hit problems.
cbauer25 5 Posted February 6, 2021 Author Posted February 6, 2021 Ok, set the app back to 5mb and still had the issue. Logs sent. Even tried going down to 1mb and it still froze. I also tried rebooting my entire setup (router, modem, switch, server). Still no luck. Nothing within my control has changed in several months. Could this be a FireTV update causing a problem?
ebr 16310 Posted February 6, 2021 Posted February 6, 2021 I'm afraid I'm not really sure at this point. The best idea I have now would be to try the current beta which does update the player.
cbauer25 5 Posted February 6, 2021 Author Posted February 6, 2021 Ok i've updated my communication preferences. Can you send the link to the beta. Thanks!
Carlo 4561 Posted February 6, 2021 Posted February 6, 2021 5 minutes ago, cbauer25 said: Ok i've updated my communication preferences. Can you send the link to the beta. Thanks! Look at message right above yours.
