leeknight1981 0 Posted January 30, 2021 Posted January 30, 2021 Hi Guy’s Can’t figure this out! So iv added Doctor Who for my dad when I log into Emby on iMac - web browser I can see it says Selection and shows me say parts 1-4 but on Apple TV it only shows Epp 1 with No Parts is it a setting I need to change? As he doesn’t have a laptop etc only an Apple TV TIA L33
ebr 16334 Posted January 30, 2021 Posted January 30, 2021 Hi. Those appear to be interpreted as multiple versions instead of multiple parts. Exactly how did you set them up? TV Naming
leeknight1981 0 Posted January 30, 2021 Author Posted January 30, 2021 (edited) I didn’t tag them this is how they come! I dropped em into FileBot but it stayed the same I assume who ever compiled them has done the S01E01 in parts not sure why. But it buy and rip the DVD’s would cost a fortune and take a decade. ill have to tag manually I think cheers L33 Edited January 30, 2021 by leeknight1981
Happy2Play 9811 Posted January 30, 2021 Posted January 30, 2021 (edited) But I can see having all of these parts in a single folder named S01E01 and files named the same being a issue. As shown from TVDB they are individual episodes and need to be named accordingly. I don't see how two clients would be looking at these differently as shown in first post though. Edited January 30, 2021 by Happy2Play
leeknight1981 0 Posted January 30, 2021 Author Posted January 30, 2021 Yeah I’ll have to manually tag the lot I Guess, I didn’t understand how the web browser shows you can watch individual parts where as Apple TV doesn’t cheers L33
Happy2Play 9811 Posted January 30, 2021 Posted January 30, 2021 4 minutes ago, leeknight1981 said: Yeah I’ll have to manually tag the lot I Guess, I didn’t understand how the web browser shows you can watch individual parts where as Apple TV doesn’t cheers L33 But Apple TV is as your picture shows each episode as a item, but personally don't understand how as it should be showing multiversion like the web client. But from a provider metadata standpoint if all the information can from TVDB, technically Apple TV is showing proper order as shown from TVDB image. The naming scheme is also confusing, so a question still is do the nfo files have metadata corresponding to naming scheme or proper metadata from provider ignoring naming scheme?
leeknight1981 0 Posted January 30, 2021 Author Posted January 30, 2021 I honestly don’t know about the .nfo data I’ll go threw and try tag manually using the names and tvdb. I’ll drag the entire folder out tv shows folder and tag them then drop the entire folder back in when as correct as I can get.
Happy2Play 9811 Posted January 30, 2021 Posted January 30, 2021 I would have thought filebot would have done everything for you.
leeknight1981 0 Posted January 30, 2021 Author Posted January 30, 2021 I would too but when I ran it threw it didn’t do anything using tvdb option! Will post a picture in the morning of filebot as done a 12 hour shift and my head hurts :) L33
Deathsquirrel 745 Posted January 31, 2021 Posted January 31, 2021 I can't say why you're getting different results in different clients. I can say this isn't a supported structure and your episode numbers are wrong so you're going to get some odd results. Here is the TV naming wiki: https://support.emby.media/support/solutions/articles/44001159110-tv-naming If you follow the naming wiki and match your titles to your metadata provider of choice, you'll have great success and it's FAR less effort than your current structure. I recommend this, assuming you use TVDB as your primary TV metadata provider: \\server\share\Doctor Who\Season 01\Doctor Who S01E01- An Unearthly Child (1).avi \\server\share\Doctor Who\Season 01\Doctor Who S01E02 The Cave of Skulls (2).avi \\server\share\Doctor Who\Season 01\Doctor Who S01E03 The Forest of Fear (3).avi \\server\share\Doctor Who\Season 01\Doctor Who S01E04 The Firemaker (4).avi I recommend pulling the entire show out, scanning, renaming/organizing the files, and then drop the show back in your TV share and doing a library scan. Should be just fine after that. I would also convert those AVIs to MKVs and probably convert them from MPEG2 to MP4, assuming these are DVD rips. Both of those changes will reduce server-side transcoding requirements. 1
Happy2Play 9811 Posted January 31, 2021 Posted January 31, 2021 36 minutes ago, Deathsquirrel said: I can say this isn't a supported structure It isn't in the KB but episode level folder are supported, but yes the overall naming will be a issue as it currently is multi-version of said episode example S01E01 is one episode not 4. Thinking about it the Apple TV may be correct as I believe you select version at time of playback but a device user or dev will have to comment. Further looking at the images All metadata is wrong and showing episode order but the media is not in episode order. The structure order of S01E02 is The Daleks, but as shown in images it is metadata provider S01E02 The Cave of Skulls (2). So every episode in the UI does not correspond with proper episodes. So a complete restructure and renaming will be required. @Luke@ebr Does that sound correct.
leeknight1981 0 Posted January 31, 2021 Author Posted January 31, 2021 7 hours ago, Deathsquirrel said: I can't say why you're getting different results in different clients. I can say this isn't a supported structure and your episode numbers are wrong so you're going to get some odd results. Here is the TV naming wiki: https://support.emby.media/support/solutions/articles/44001159110-tv-naming If you follow the naming wiki and match your titles to your metadata provider of choice, you'll have great success and it's FAR less effort than your current structure. I recommend this, assuming you use TVDB as your primary TV metadata provider: \\server\share\Doctor Who\Season 01\Doctor Who S01E01- An Unearthly Child (1).avi \\server\share\Doctor Who\Season 01\Doctor Who S01E02 The Cave of Skulls (2).avi \\server\share\Doctor Who\Season 01\Doctor Who S01E03 The Forest of Fear (3).avi \\server\share\Doctor Who\Season 01\Doctor Who S01E04 The Firemaker (4).avi I recommend pulling the entire show out, scanning, renaming/organizing the files, and then drop the show back in your TV share and doing a library scan. Should be just fine after that. I would also convert those AVIs to MKVs and probably convert them from MPEG2 to MP4, assuming these are DVD rips. Both of those changes will reduce server-side transcoding requirements. Yea it’s something I downloaded unfortunately so I have had no input on them, When I Rip using MakeMKV I follow the normal profile S01E00 S01E01 and so on. I’m not going to bother changing the formats tbh as it is only for my dad and my server has 32 3.33GHz cores and a P2000 GPU but I’ll manually tag it myself as I know how the tagging should be but never seen it done like that in parts. And being able to select which part in one client and not another threw me thanks Guy’s
