Aeit 0 Posted January 30, 2021 Posted January 30, 2021 (edited) I feel like there should be checkboxes for these. If I want to mix actors and genres to see both of them. Right now I have to add actor name as a tag to achieve that. Also side question, is there a way to display a row of actors on homescreen instead of continue listening or LiveTV? Edited January 30, 2021 by Aeit
Luke 42204 Posted January 31, 2021 Posted January 31, 2021 Quote Also side question, is there a way to display a row of actors on homescreen instead of continue listening or LiveTV? Hi, no, but perhaps in the future via a smart views/playlists feature that we'd like to do.
Aeit 0 Posted January 31, 2021 Author Posted January 31, 2021 13 hours ago, Luke said: Hi, no, but perhaps in the future via a smart views/playlists feature that we'd like to do. Oh thanks. Could you tell me. If I spend days editing my metadata for each of 1k movies is there a way to save this? Even if i move them between drives or clouds?
Luke 42204 Posted January 31, 2021 Posted January 31, 2021 Yes I would suggest enabling the library options to save metadata to nfo files, as well as saving images to original media folders.
Aeit 0 Posted January 31, 2021 Author Posted January 31, 2021 5 minutes ago, Luke said: Yes I would suggest enabling the library options to save metadata to nfo files, as well as saving images to original media folders. Thanks, looks like I always had this enabled, cause I have ".bif" file for every video.
Luke 42204 Posted January 31, 2021 Posted January 31, 2021 Actually thumbnails have their own dedicated option.
