justinrh 264 Posted January 28, 2021 Posted January 28, 2021 (edited) I'm thinking the network settings documentation is out-of-date. There are settings missing, arranged differently, and terminology is different. https://support.emby.media/support/solutions/articles/44001159601-network-hosting-settings The first thing I noticed, for example, was that the UI says "External domain: If you have a dynamic DNS or domain name, enter it here, without protocol or port. Emby apps will use it when connecting remotely. This field is required when used with a custom ssl certificate. Example: mydomain.com." But doc page has a section "External WAN Address". Edited October 16, 2021 by justinrh
Luke 42204 Posted January 28, 2021 Posted January 28, 2021 Hi, thanks for reporting. We'll take a look. @cayars
Carlo 4561 Posted January 28, 2021 Posted January 28, 2021 I'll review the info but most likely will be reworking some of these pages shortly or just removing/replacing them. If you're trying to setup remote access try this guide "Remote Access"https://support.emby.media/support/solutions/articles/44002137137-remote-setup This covers the basics of getting remote access to your Emby server. I'm following up this week with more advanced details that go into SSL setup, cert conversions, advanced port mapping and maybe Emby use behind proxies. 1
justinrh 264 Posted January 29, 2021 Author Posted January 29, 2021 @cayars, there are a couple of typos on that page also. Please look at https://support.emby.media/support/solutions/articles/44001848833-cinema-intros I think "navigating to Playback -> Cinema Intros" should be "... Server -> Cinema Intros".
Carlo 4561 Posted January 29, 2021 Posted January 29, 2021 2 hours ago, justinrh said: @cayars, there are a couple of typos on that page also. Thank you, fixed.
