steveblair 14 Posted January 28, 2021 Posted January 28, 2021 After upgrading to the latest beta, playlists no longer seem to work on the Roku client. When select an existing playlist, it shows the correct total number of items that are supposed to be in playlist (directly below the title), but then just shows "No Items" where the playlist should be. Clicking on "Play All" gives me a "Playback Error". The Playlists work fine on the web client and android (and were working fine on the Roku previously).
Luke 42241 Posted January 28, 2021 Posted January 28, 2021 Hi there, can you please attach the emby server log from when this happened? Thanks.
steveblair 14 Posted January 28, 2021 Author Posted January 28, 2021 Thanks for looking into this...I rotated the log files before trying to duplicate the error so I hope this captures everything you need. embyserver.txt
Luke 42241 Posted January 28, 2021 Posted January 28, 2021 Hi, are these playlists containing videos?
steveblair 14 Posted January 28, 2021 Author Posted January 28, 2021 Yes, these are all video playlists.
speechles 2062 Posted January 28, 2021 Posted January 28, 2021 Reference: Issue #1043: Playlists not working with 4.6.0.20 beta We will see what is happening and make adjustments to correct it. Thanks for spotting it. Any others you find please let us know. Thanks.
Luke 42241 Posted January 28, 2021 Posted January 28, 2021 It currently looks like the app is only supporting audio playlists so I don't think this would have ever worked.
speechles 2062 Posted January 28, 2021 Posted January 28, 2021 (edited) The application supports both video and audio playlists. The detection of which is which may be off. If there is not a mediaType for the playlist it will assume it is audio. I am suspect playlists lost their mediatype and now video playlists are not report as mediatype = video. If the mediaType field is empty this used to be how audio playlists presented themselves they had an empty mediaType field. This is why it may incorrectly assume it is an audio playlist. I have not updated to this beta version yet so cannot tell exactly what is wrong only take an educated guess. I am going to make a second instance of Emby server to install this new Beta and figure this out. Edited January 28, 2021 by speechles 1
steveblair 14 Posted January 29, 2021 Author Posted January 29, 2021 Not sure if this helps or not, but just for interests sake, if I cast a playlist from my android phone to the roku, the playlist plays correctly.
steveblair 14 Posted January 31, 2021 Author Posted January 31, 2021 One more piece of info, I believe your assumption that Roku thinks these are audio playlists is correct. After getting the Playback Error, once I hit okay, it goes to a black screen with audio controls along the bottom (previous, play, forward, repeat, random, etc...) with a spinning circle that never goes away. Selecting "Play" closes Emby and returns to the Roku Home Page. Is there a way to manually indicate these playlists as "video"? (perhaps by editing the playlist xml directly?)
speechles 2062 Posted January 31, 2021 Posted January 31, 2021 (edited) 50 minutes ago, steveblair said: One more piece of info, I believe your assumption that Roku thinks these are audio playlists is correct. After getting the Playback Error, once I hit okay, it goes to a black screen with audio controls along the bottom (previous, play, forward, repeat, random, etc...) with a spinning circle that never goes away. Selecting "Play" closes Emby and returns to the Roku Home Page. Is there a way to manually indicate these playlists as "video"? (perhaps by editing the playlist xml directly?) The way the Roku works is a bit different. It expects the playlist to obtain a MediaType during the initial fetch. It does not yet know the contents of the playlist to know what it is composed of. The video playlists used to populate the MediaType field with "video" as the value. This made it possible to redirect to each handler: video, photo, or audio. With the MediaType now missing this makes it fall back to "audio" as the only type playlists can handle presently. We apologize. We are working on a solution and should have one shortly. Please stay tuned. Edited January 31, 2021 by speechles 1
steveblair 14 Posted January 31, 2021 Author Posted January 31, 2021 Thanks for the explanation and for looking into this, much appreciated!
ebr 16335 Posted February 6, 2021 Posted February 6, 2021 Can you please test this with the latest Roku beta? Thanks.
steveblair 14 Posted February 8, 2021 Author Posted February 8, 2021 Seems to be working in the beta....thanks! 1
