Taurec 60 Posted January 27, 2021 Posted January 27, 2021 Hello, I need an idea to compare the number of elements in my libraries with the number of folders on the hard drive. I have several libraries with TV shows, TV shows, kids, TC show documentaries, etc. e.g. the Librayry TV show shows me 2300 items 2312 are displayed in the folder view. There are actually 2348 folders in the folder on the hard drive. Does anyone have an idea how I can find out which elements I am missing. (that the number of elements does not match the number of folders on the hard disk for each library created) I hope someone has a useful idea. thx Taurec
Happy2Play 9802 Posted January 27, 2021 Posted January 27, 2021 Maybe the Reports plugin exporting a csv/excel and a command line list of folders,
Taurec 60 Posted January 27, 2021 Author Posted January 27, 2021 yes, the report plugin export a list of TV-Shows. But the export contain all TV-Shows, no split to assigned Library. The export is not helpful really. thx
PenkethBoy 2068 Posted January 27, 2021 Posted January 27, 2021 do a search for empty folders might show up some of the differences
Taurec 60 Posted January 27, 2021 Author Posted January 27, 2021 mhm... sorry no empty folder is there a way to get a list of elements via swagger?
GrimReaper 4861 Posted January 27, 2021 Posted January 27, 2021 Just now, Taurec said: mhm... sorry no empty folder is there a way to get a list of elements via swagger? Do any of your TV Show folders belong to multiple Libraries?
Taurec 60 Posted January 27, 2021 Author Posted January 27, 2021 Hi, all libraries have their own folder on the hard disk. e.g. TV shows -> \ TV shows (Elements Library=2300, Elements Folderview=2312, Elements HDD=2348) TV-Shows Kids -> \ TC-Shows_Kids (Elements Library=415, Elements Folderview=422, Elements HDD=437) TV shows documentary -> \ TC-Shows_Doku (Elements Library=807, Elements Folderview=821, Elements HDD=844) The export from report plugin create a list of elements. (may this is a feature request for the plugin "localpath"
GrimReaper 4861 Posted January 27, 2021 Posted January 27, 2021 And what is the total number of Series that Reports plugin returns? 3522?
Taurec 60 Posted January 27, 2021 Author Posted January 27, 2021 The report shows me the sum of all elements in the library = 3522
GrimReaper 4861 Posted January 27, 2021 Posted January 27, 2021 Just now, Taurec said: The report shows me the sum of all elements in the library = 3522 Then you should do as @Happy2Play suggested, just concatenate those 3 folderlists into single one and compare against Reports "Series" export, should be quite straightforward to spot the differences.
GrimReaper 4861 Posted January 27, 2021 Posted January 27, 2021 27 minutes ago, Taurec said: The export from report plugin create a list of elements. (may this is a feature request for the plugin "localpath" Path for "Series" view wouldn't make much sense as they can be spread across multiple folders and/or drives, unlike "Movies" and "Episodes" (for which there is) whose location, in general, can be pinpointed. What could possibly produce the result you desire is to introduce another top-level menu in left-side dropdown chooser, under "Media" and "Activity", call it "Library", after which right-side dropdown will list your Libraries and upon selection would basically present 'restricted' "Series" view limited to chosen Library and could be further manipulated or exported from there.
Taurec 60 Posted January 27, 2021 Author Posted January 27, 2021 At the moment I can only compare the export of the report plugin (contains all elements of the TV shows) with a folder list created on the HDD. I can then analyze the differences and, if necessary, find out why the number of elements between Library / Folderview and HDD are present. Thanks for your suggestions, but as long as it is not possible to export the elements of the individual libraries, you have to take the detour.
GrimReaper 4861 Posted January 27, 2021 Posted January 27, 2021 Just now, Taurec said: At the moment I can only compare the export of the report plugin (contains all elements of the TV shows) with a folder list created on the HDD. I can then analyze the differences and, if necessary, find out why the number of elements between Library / Folderview and HDD are present. Thanks for your suggestions, but as long as it is not possible to export the elements of the individual libraries, you have to take the detour. I'm not quite sure I'm following you, even if a smaller subset was exportable, you would still have to do same job, compare two columns of data, just separately for each Library, so the net result would actually be the same?
Taurec 60 Posted January 27, 2021 Author Posted January 27, 2021 yes you are right, it's the same job. it's just my personal way of working. I like to finish something and if I need several steps then I like to produce partial results.
GrimReaper 4861 Posted January 27, 2021 Posted January 27, 2021 Just now, Taurec said: yes you are right, it's the same job. it's just my personal way of working. I like to finish something and if I need several steps then I like to produce partial results. Fair enough. Cheers
