Pancake2 0 Posted January 27, 2021 Posted January 27, 2021 Hello all, I'm not a complete beginner, but I need some help with setting the permissions on my mount on raspbian. I have a USB hdd owned by root, but with 777 permissions. Emby server accesses it OK with the emby user. However, I keep getting lots of errors with the configuration backup plugin, although the files seem to still be copied. My logs get flooded with messages like this: 2021-01-27 00:10:30.941 Error Server Configuration Backup: Error Copying /var/lib/emby/root/default/Playlists/options.xml to /mnt/JP/emby/Emby Backup - 2021-01-27 00.10.30 - Auto/library/Playlists/options.xml *** Error Report *** Version: 4.5.4.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_armhf.deb Operating system: Linux version 5.4.83-v7+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1379 SMP Mon Dec 14 13:08:57 GMT 2020 Framework: .NET Core 3.1.8 OS/Process: arm/arm Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /opt/emby-server/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path is denied. ---> System.IO.IOException: Operation not permitted --- End of inner exception stack trace --- at System.IO.FileSystem.CopyFile(String sourceFullPath, String destFullPath, Boolean overwrite) at System.IO.File.Copy(String sourceFileName, String destFileName, Boolean overwrite) at Emby.Server.Implementations.IO.ManagedFileSystem.CopyFile(String source, String target, Boolean overwrite) at MBBackup.ServerEntryPoint.CopyFile(String source, String target, Boolean createDirectory) Source: System.IO.FileSystem TargetSite: Void CopyFile(System.String, System.String, Boolean) InnerException: System.IO.IOException: Operation not permitted Source: TargetSite:
mastrmind11 722 Posted January 27, 2021 Posted January 27, 2021 5 hours ago, Pancake2 said: /mnt/JP/emby/ emby needs to have write permission to this folder
Pancake2 0 Posted January 27, 2021 Author Posted January 27, 2021 2 minutes ago, mastrmind11 said: emby needs to have write permission to this folder I gave it 777 permission with chmod, shouldn't that work?
mastrmind11 722 Posted January 27, 2021 Posted January 27, 2021 what is the output of ls -l on that directory?
Pancake2 0 Posted January 27, 2021 Author Posted January 27, 2021 1 hour ago, mastrmind11 said: what is the output of ls -l on that directory? pi@raspberrypi:/mnt/JP/emby $ ls -l total 20 drwxrwxrwx 1 root root 4096 Jan 24 00:10 'Emby Backup - 2021-01-24 00.10.5 - Auto' drwxrwxrwx 1 root root 4096 Jan 25 00:10 'Emby Backup - 2021-01-25 00.10.5 - Auto' drwxrwxrwx 1 root root 4096 Jan 26 00:10 'Emby Backup - 2021-01-26 00.10.5 - Auto' drwxrwxrwx 1 root root 4096 Jan 26 16:36 'Emby Backup - 2021-01-26 16.36.33 - Auto' drwxrwxrwx 1 root root 4096 Jan 27 00:10 'Emby Backup - 2021-01-27 00.10.30 - Auto'
mastrmind11 722 Posted January 27, 2021 Posted January 27, 2021 well it's clearly writing the files, so it's not that directory. how about the permissions on /opt/emby-server/system
Pancake2 0 Posted January 27, 2021 Author Posted January 27, 2021 Ok, I fixed it by editing the fstab file and setting emby as the owner. After restart, I'm still getting one error when emby starts, is it related? Quote 2021-01-27 15:08:09.895 Error Server: Error processing request *** Error Report *** Version: 4.5.4.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_armhf.deb Operating system: Linux version 5.4.83-v7+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1379 SMP Mon Dec 14 13:08:57 GMT 2020 Framework: .NET Core 3.1.8 OS/Process: arm/arm Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /opt/emby-server/system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at Emby.Server.Implementations.IO.SharpCifsFileSystem.IsEnabledForPath(String path) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, FileOpenOptions fileOpenOptions) at MediaBrowser.Providers.Manager.ProviderManager.SaveImage(BaseItem item, String source, ReadOnlyMemory`1 mimeType, ImageType type, Nullable`1 imageIndex, Nullable`1 saveLocallyWithMedia, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.LibraryManager.GetLazyImage(String key, BaseItem item, ImageType type, Int32 imageIndex, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.LibraryManager.ConvertImageToLocal(BaseItem item, ItemImageInfo image, Int32 imageIndex, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.ProcessImage(ImageProcessingOptions options, CancellationToken cancellationToken) at MediaBrowser.Api.Images.ImageService.GetImage(ImageRequest request, Int64 itemId, BaseItem item, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Boolean IsEnabledForPath(System.String)
Luke 42246 Posted January 27, 2021 Posted January 27, 2021 3 hours ago, Pancake2 said: Ok, I fixed it by editing the fstab file and setting emby as the owner. After restart, I'm still getting one error when emby starts, is it related? Please attach the complete log file. Also what problem are you having?
Pancake2 0 Posted January 27, 2021 Author Posted January 27, 2021 2 hours ago, Luke said: Please attach the complete log file. Also what problem are you having? Actually I'm not having any problems, I was just checking the logs and got curious with that error.
Pancake2 0 Posted January 27, 2021 Author Posted January 27, 2021 Here is the log requested. The error seems to happen a couple of times. embyserver-63747380151.txt
Solution Luke 42246 Posted January 28, 2021 Solution Posted January 28, 2021 Ok it's nothing to worry about. We'll clean up that logging. Thanks.
