test399 0 Posted January 26, 2021 Posted January 26, 2021 (edited) So i recently swapped out motherboards which also changed the IP address of my Emby server running on Win 10. It always causes me pain. My problem is I have xteve running from a file on my pc and it wont stay on. I've tried using programs like Always Up (what i typically use for xteve) and Task Scheduler, and also tried starting from Services.msc but Xteve wont stay on.... It turns on for like 30 seconds then shuts off. I cant get my Emby guide working. My providers Xmltv file is impossible to use without Xteve. Thanks Is there some cache i have to clear to get Xteve to stay on or something? Or Are Xteve Servers broken or down? I know there was a big internet outage for Eastern USA yesterday for Verizon Fios. Edited January 26, 2021 by test399
Spaceboy 2573 Posted January 26, 2021 Posted January 26, 2021 i would check your xteve logs, i dont think xteve not being able to check for updates would cause it to crash
test399 0 Posted January 26, 2021 Author Posted January 26, 2021 ok i thought maybe xteve had like a server that feeds it info idk. Check xteve logs for why its not staying on?
test399 0 Posted January 26, 2021 Author Posted January 26, 2021 Ok, i think i need to uninstall and reinstall xteve. How would one go about wiping xteve and its caches etc, and clean installing xteve? I need to start over but dont know how.
Spaceboy 2573 Posted January 27, 2021 Posted January 27, 2021 yeah there doesnt seem to be a way to see xteve logs outside of the web browser just delete the xteve or the .xteve folder from your user folder (if windows) keeping a backup so you can restore if possible i run xteve as a service using Non Sucking Service Manager
test399 0 Posted January 27, 2021 Author Posted January 27, 2021 Non Sucking Service manager. That's hilarious i totally thought it was a joke
pwhodges 2033 Posted January 27, 2021 Posted January 27, 2021 Indeed not! It's the preferred way to set up Windows services. I use it for my web server and such, as well as for Emby. Paul
test399 0 Posted January 31, 2021 Author Posted January 31, 2021 so i am going crazy here. I even did a clean install of windows 10 and still for some reason, always up, my program of choice will start xteve if i click on start, but it doesnt stay on... Can anyone think of any reason why xteve doesnt want to stay on? (i'm not talking about after a restart, xteve SHUTS DOWN minutes after MANUALLY starting???!!!#$ without reboot!!!) WTH!!! Did i forget something during setup? WTH is my XTEVE SHUTTING DOWN MINUTES AFTER STARTING IT !!!!!???????????????????????
Spaceboy 2573 Posted January 31, 2021 Posted January 31, 2021 Have you tried the xteve discord? They may have more ideas
BillOatman 597 Posted February 3, 2021 Posted February 3, 2021 Check the xteve settings too. I think there is a IP address oy may need to change @test399
