MartynSteph 0 Posted January 26, 2021 Posted January 26, 2021 Hi I'm sure this will be a very easy fix for most but I'm clueless. In the last week or so I've had to re identify lots of my tv show. It lasts for a few days but then clears. This doesn't happen to all but does happen to a significant amount. I've added the log, sure its something simple. Thanks in advance embyserver.txt
Luke 42204 Posted January 26, 2021 Posted January 26, 2021 Hi there, can you please go over an example? Thanks.
Nicrophilia1978 0 Posted January 26, 2021 Posted January 26, 2021 Hi this is my post (still logged in as my dad when I set his up) Yeah so for example it only happened the other week for the first time, loads of my tv shows suddenly lost all pictures and I had to re identify them. Thought nothing of it but a couple of days later it happened again so I've now downloaded the last log from when it happened. Cheers Nick
Happy2Play 9802 Posted January 26, 2021 Posted January 26, 2021 What is your E:\ drive? I would appear it disconnect and all items get removed then readded. 2021-01-26 00:05:30.751 Error App: Error resolving path E:\TV shows\You.S02.xxxxxxxxxxxxxxxxxxxxxxxxxx Second your structure is improper as every Series has to have a series folder, you are attempting to add season folders. Emby TV Naming : Emby
Nicrophilia1978 0 Posted January 26, 2021 Posted January 26, 2021 Hi the e drive is just a 6tb hard drive. What would be the best way to improve the structure? Cheers Nick
Luke 42204 Posted January 26, 2021 Posted January 26, 2021 26 minutes ago, Nicrophilia1978 said: Hi the e drive is just a 6tb hard drive. What would be the best way to improve the structure? Cheers Nick Have you taken a look at our TV naming guide? https://support.emby.media/support/solutions/articles/44001159110-tv-naming
Nicrophilia1978 0 Posted January 27, 2021 Posted January 27, 2021 Ueah all sorted thanks for the help and quick responses
