Josetiko 0 Posted January 25, 2021 Posted January 25, 2021 Hi there! I'm trying to setup Emby to read my media from external hard drives on an Android TV box (S95X Pro), while I access the media from a Firestick. I was able to setup the server, and I can see all my movies both from my laptop and the firestick. But whenever I click Play, I get an error and nothing plays. I'm attaching a log example, and I'm pasting it below too since on my end the txt looks horrible, without line breaks, not sure why. 2021-01-23 17:22:19.975 Operating System: Android 6.0.1 (REL) SDK:M BuildId:MHC19J Incremental:20170420 Patch-Level: 2016-08-01 OS/Process: Arm/Arm Emby Server version: 4.5.4.0 Operating system: Unix 3.14.29.0 Command Line: /data/app/com.emby.embyserver-1/base.apk App: AndroidTv 1.8.54a Joses Fire TV Stick http://192.168.1.24:8096/emby/videos/2050/live.m3u8?DeviceId=933edeec26bfb988&MediaSourceId=af94fab3fd7304c658e2512f225568d9&PlaySessionId=4f21507858a9487daf1d1e3592f1f2d7&api_key=a3e7ab67995e43809fcf10d9efaafe10&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,aac,mp3&VideoBitrate=79808000&AudioBitrate=192000&MaxHeight=1080&SubtitleMethod=Encode&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=41&hevc-profile=Main&eac3-audiochannels=6&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=VideoCodecNotSupported {"Protocol":"File","Id":"af94fab3fd7304c658e2512f225568d9","Path":"/storage/8A789E2D789E17D1/4 PELICULAS II/Coherence (2013) [1080p]/Coherence.2013.1080p.BluRay.x264.YIFY.mp4","Type":"Default","Container":"mp4","Size":0,"Name":"Coherence.2013.1080p.BluRay.x264.YIFY","IsRemote":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[],"Formats":[],"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false} >>>>>> User policy for Josetiko EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True /data/data/com.emby.embyserver/files/ffmpeg/ffmpeg -y -copyts -start_at_zero -f mp4 -i "/storage/8A789E2D789E17D1/4 PELICULAS II/Coherence (2013) [1080p]/Coherence.2013.1080p.BluRay.x264.YIFY.mp4" -map 0:0 -vn -sn -c:a:0 copy -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/storage/emulated/0/Android/data/com.emby.embyserver/files/transcoding-temp/1B275C.m3u8" -segment_list_type m3u8 -segment_time 3 -segment_list_entry_prefix hls/1B275C/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 "/storage/emulated/0/Android/data/com.emby.embyserver/files/transcoding-temp/1B275C_%d.ts" WARNING: linker: /data/data/com.emby.embyserver/files/ffmpeg/ffmpeg: unused DT entry: type 0x1d arg 0x1001 CANNOT LINK EXECUTABLE: library "libembymc.so" not found ffmpeg-transcode-50a47cf6-d352-4693-87bb-1d5ad2cca376_1.txt
Luke 42239 Posted January 28, 2021 Posted January 28, 2021 Hi there, are you able to update this box to a newer version of android?
