invertedknife 13 Posted August 6, 2014 Posted August 6, 2014 Is it possible to display quality tags in the web interface? such as (1080p, 720p, 526p etc) 1
Koleckai Silvestri 1154 Posted August 6, 2014 Posted August 6, 2014 It does this on the Media Info tab when you're looking at the Item Details.
psykix 97 Posted August 6, 2014 Posted August 6, 2014 Think he means the logos. It would look quite nice alongside the rating here :-
Koleckai Silvestri 1154 Posted August 6, 2014 Posted August 6, 2014 Hmm. I am of the mind that less is more there but I guess some people want it. I even think having the logo and the poster is extraneous here. 2
Danee 57 Posted August 6, 2014 Posted August 6, 2014 That may be nice for the tech savvy, but I'm sure my wife will ask why it's there and if I can remove it and I'll bet I'm not not the only one getting such questions.
Deathsquirrel 745 Posted August 6, 2014 Posted August 6, 2014 You might want to consider using the coverart plugin. It makes identifying which movies are HD and which aren't pretty darn simple.
speechles 2062 Posted August 6, 2014 Posted August 6, 2014 Danee, and your wife would ask that once unless this is "50 first dates" and Deathsquirrel, not the same thing at all as the request The roku client shows this information, the request makes sense. Sent from my ASUS Transformer Pad TF300T using Tapatalk
speechles 2062 Posted August 6, 2014 Posted August 6, 2014 (edited) note: I assume he means the information given when playing videos through the web interface and it is playing. The poster and logo do show up here. I also assume Wayne Luke meant this same thing in his comment. Just to clarify. ....and I meant to edit my post above, this one can be merged into the one above it when a moderator reads this. Sent from my ASUS Transformer Pad TF300T uing Tapatalk Edited August 6, 2014 by speechles
kronic24601 1 Posted August 7, 2014 Posted August 7, 2014 The coverart plugin has this option. You can place it's quality in a configurable corner over the artwork (in the MetaData Indicator overlays section). 1
invertedknife 13 Posted August 17, 2014 Author Posted August 17, 2014 (edited) i meant something like this. helps to identify the quality of my colelction when i am managing it. Edited August 17, 2014 by invertedknife
