Itzdibbyyx 4 Posted January 24, 2021 Posted January 24, 2021 hello, I noticed today that emby theater is not playing surround sound properly i think it maybe the centre channel thats broken? my layout is set to 5.1 and it seems the the centre channel is being split between the front left and right speakers. the play method is DirectPlay and stats for nerds is showing that the media is 5.1 i can play the same movie/file via VLC or windows 'Films & TV' application and i can distinctly hear the dialouge on the centre channel whereas on emby it would be split between the front left and right channel... any help would be appreciated
Happy2Play 9811 Posted January 24, 2021 Posted January 24, 2021 A ET guru will have to comment more, but which version of ET are you running? You can see the version number at the bottom of your user preference menu (user icon). You will probably need to post your ET Audio settings and your system audio settings. Similar to this post.
Itzdibbyyx 4 Posted January 24, 2021 Author Posted January 24, 2021 7 minutes ago, Happy2Play said: A ET guru will have to comment more, but which version of ET are you running? You can see the version number at the bottom of your user preference menu (user icon). You will probably need to post your ET Audio settings and your system audio settings. Similar to this post. version 3.0.14 i'm using an optical cable from the sound blaster card straight into my reciever so i don't think passthrough applies...
Happy2Play 9811 Posted January 24, 2021 Posted January 24, 2021 Can you also post the media info for a specific item you are having issues with along with the Stats for Nerds pop up screen results. This should provide almost all the information required.
sooty234 266 Posted January 24, 2021 Posted January 24, 2021 If you're using optical, disable everything except DTS and AC3. Then make sure Windows audio is set to stereo. If you want to convert the unsupported audio to AC3 so you can still have 5.1 surround sound, I will have to help you further with that. It will require a more advanced configuration, but is actually quite easy to do. 1
Itzdibbyyx 4 Posted January 24, 2021 Author Posted January 24, 2021 6 minutes ago, Happy2Play said: Can you also post the media info for a specific item you are having issues with along with the Stats for Nerds pop up screen results. This should provide almost all the information required.
Itzdibbyyx 4 Posted January 24, 2021 Author Posted January 24, 2021 14 minutes ago, sooty234 said: If you're using optical, disable everything except DTS and AC3. Then make sure Windows audio is set to stereo. If you want to convert the unsupported audio to AC3 so you can still have 5.1 surround sound, I will have to help you further with that. It will require a more advanced configuration, but is actually quite easy to do. as expected that resulted in everything playing in stereo... the audio is not unsupported this problem is soley on ET, the web browser client plays the surround sound just fine
sooty234 266 Posted January 24, 2021 Posted January 24, 2021 1 minute ago, Itzdibbyyx said: as expected that resulted in everything playing in stereo... the audio is not unsupported this problem is soley on ET, the web browser client plays the surround sound just fine Yes, this is because optical doesn't support what you're trying to force down it. But I can give you a way for mpv to convert the unsupported audio to AC3 5.1
sooty234 266 Posted January 24, 2021 Posted January 24, 2021 I'm attaching a zip file that contains a folder. Unzip the folder to; C:\users\USERNAME\AppData\Roaming And try playing your videos with only DTS and AC3 enabled in the audio settings. mpv.zip
Itzdibbyyx 4 Posted January 24, 2021 Author Posted January 24, 2021 2 minutes ago, sooty234 said: Yes, this is because optical doesn't support what you're trying to force down it. But I can give you a way for mpv to convert the unsupported audio to AC3 5.1 im confused? any other player including emby web browser can play the files with the centre channel properly... it makes little sense to convert the audio for near on all of my films when it should work... 6 minutes ago, sooty234 said: I'm attaching a zip file that contains a folder. Unzip the folder to; C:\users\USERNAME\AppData\Roaming And try playing your videos with only DTS and AC3 enabled in the audio settings. mpv.zip 303 B · 0 downloads that results in nothing loading/constant loading wheel
sooty234 266 Posted January 24, 2021 Posted January 24, 2021 1 minute ago, Itzdibbyyx said: im confused? any other player including emby web browser can play the files with the centre channel properly... it makes little sense to convert the audio for near on all of my films when it should work... That's because the server transcodes the audio. mpv is more capable than the server. 2 minutes ago, Itzdibbyyx said: that results in nothing loading/constant loading wheel Please show me screenshots of the files you created from what I gave you, and the current settings in Theater.
sooty234 266 Posted January 24, 2021 Posted January 24, 2021 To be clear, this will happen as you play the file. You're not altering the file in your library.
Itzdibbyyx 4 Posted January 24, 2021 Author Posted January 24, 2021 6 minutes ago, sooty234 said: That's because the server transcodes the audio. mpv is more capable than the server. Please show me screenshots of the files you created from what I gave you, and the current settings in Theater. what settings do you want to see? theres a lot of them
Itzdibbyyx 4 Posted January 24, 2021 Author Posted January 24, 2021 9 minutes ago, sooty234 said: That's because the server transcodes the audio. mpv is more capable than the server. Please show me screenshots of the files you created from what I gave you, and the current settings in Theater. Im pretty sure emby is not involved with the default windows Films and TV application or VLC player either but also...
Happy2Play 9811 Posted January 24, 2021 Posted January 24, 2021 That stats shows the server converting the mp4 and steaming in via http, and converting the Video from h265 to h264 while sending audio as is. So a full transcode of the videos stream as it shows unsupported how ever you provided this example.
Itzdibbyyx 4 Posted January 24, 2021 Author Posted January 24, 2021 3 minutes ago, Happy2Play said: That stats shows the server converting the mp4 and steaming in via http, and converting the Video from h265 to h264 while sending audio as is. So a full transcode of the videos stream as it shows unsupported how ever you provided this example. agreed, thats why i can't understand why ET is having a problem... in theory it should be fine
sooty234 266 Posted January 24, 2021 Posted January 24, 2021 (edited) Okay, so we're dealing with AAC? Let's get some logging. In that mpv.conf, add this line at the top; log-file="C:\Users\lynn\Desktop\mpv_log.txt" Play once. A log should appear on your desktop. Please attach that. Edited January 24, 2021 by sooty234
Itzdibbyyx 4 Posted January 24, 2021 Author Posted January 24, 2021 1 minute ago, sooty234 said: Okay, so we're dealing with AAC? Let's get some logging. In that mpv.conf, add this line at the top; log-file="C:\Users\lynn\Desktop\mpv_log.txt" Play once. A log should appear on your desktop. Please attach that. i will do this tomorrow, its 4AM for me now i gotta sleep, cheers for the help so far guys 1
Itzdibbyyx 4 Posted January 24, 2021 Author Posted January 24, 2021 5 minutes ago, sooty234 said: Okay, so we're dealing with AAC? Let's get some logging. In that mpv.conf, add this line at the top; log-file="C:\Users\lynn\Desktop\mpv_log.txt" Play once. A log should appear on your desktop. Please attach that. okay now im going to sleep :L mpv_log.txt
sooty234 266 Posted January 24, 2021 Posted January 24, 2021 I think your sample rate is set too high. [ 0.773][d][ao/wasapi] Probing formats [ 0.781][v][ao/wasapi] Trying stereo float (32/32 bits) @ 96000hz (shared) -> ok [ 0.781][v][ao/wasapi] Accepted as stereo float @ 96000hz -> stereo float (32/32 bits) @ 96000hz (shared) [ 0.781][d][ao/wasapi] Fixing format [ 0.781][d][ao/wasapi] IAudioClient::GetDevicePeriod [ 0.782][v][ao/wasapi] Device period: 10 ms [ 0.782][d][ao/wasapi] IAudioClient::Initialize [ 0.793][d][ao/wasapi] IAudioClient::Initialize pRenderClient [ 0.793][d][ao/wasapi] IAudioClient::Initialize IAudioClient_SetEventHandle [ 0.793][d][ao/wasapi] IAudioClient::Initialize IAudioClient_GetBufferSize [ 0.793][v][ao/wasapi] Buffer frame count: 4800 (50 ms) [ 0.793][v][ao/wasapi] IAudioClock::GetFrequency gave a frequency of 768000. [ 0.796][d][ao/wasapi] IAudioClient::Initialize pAudioVolume [ 0.796][d][ao/wasapi] Entering dispatch loop [ 0.796][d][ao/wasapi] Init wasapi done [ 0.796][v][ao/wasapi] device buffer: 4800 samples. [ 0.796][v][ao/wasapi] using soft-buffer of 19200 samples. [ 0.796][i][cplayer] AO: [wasapi] 96000Hz stereo 2ch float [ 0.796][v][cplayer] AO: Description: Windows WASAPI audio output (event mode) [ 0.796][v][autoconvert] inserting resampler [ 0.796][v][swresample] format change, reinitializing resampler [ 0.796][v][swresample] 48000Hz stereo floatp -> 96000Hz stereo float [ 0.796][v][af] [out] 96000Hz stereo 2ch float [ 9.151][v][af] [in] 48000Hz 5.1 6ch floatp [ 9.151][v][af] [lavcac3enc] 48000Hz 5.1 6ch floatp [ 9.152][v][af] [userspeed] 48000Hz stereo 2ch spdif-ac3 [ 9.152][v][af] [userspeed] (disabled) [ 9.152][v][af] [convert] 48000Hz stereo 2ch spdif-ac3 You've got some things not how I would expect them to be. You have a 2080 Ti but you haven't enabled hardware acceleration. Set that to auto. And take a look at how you've configured the sample rate in Windows. You are you using optical. You should leave that at 48000Hz.
sooty234 266 Posted January 24, 2021 Posted January 24, 2021 Something isn't right, here. What audio device are you using? What's the make and model?
Itzdibbyyx 4 Posted January 24, 2021 Author Posted January 24, 2021 5 hours ago, sooty234 said: Something isn't right, here. What audio device are you using? What's the make and model? creative sound blaster z pci-e card plugged in via optical to a logitech z906
Itzdibbyyx 4 Posted January 24, 2021 Author Posted January 24, 2021 6 hours ago, sooty234 said: Something isn't right, here. What audio device are you using? What's the make and model? this is how its set up, you have to use the Speakers option to get sound from the optical cable (as recomended by the software for the sound blaster Z)
Itzdibbyyx 4 Posted January 24, 2021 Author Posted January 24, 2021 8 hours ago, sooty234 said: Okay, so we're dealing with AAC? Let's get some logging. In that mpv.conf, add this line at the top; log-file="C:\Users\lynn\Desktop\mpv_log.txt" Play once. A log should appear on your desktop. Please attach that. as another example when i play another film via the web browser vs the ET app
Itzdibbyyx 4 Posted January 24, 2021 Author Posted January 24, 2021 okay so I unchecked all audio passthrough options (i only had ac3 and dts checked) and that at least got Openal to 'play' 5.1 however the sound being played is still having the centre channel played via the FL/FR channels, it sounds like its playing 4.0/4.1
