thelangs 2 Posted January 24, 2021 Posted January 24, 2021 When you have a movie that has two disks, I don't have any problems playing them, etc. My question is the "time" value. The length of the movie shows the first disk time, the second disk shows the same time as the first disk. Is there anyway to either show the correct time for the second disk or better the total time for entire movie?
PenkethBoy 2068 Posted January 24, 2021 Posted January 24, 2021 join them together as one file can be done with mkvtoolnix or ffmpeg or other tools 3
Luke 42204 Posted January 24, 2021 Posted January 24, 2021 Hi, yes we need to improve our multi-disc support, but even once that happens you'll always get a better experience from just joining the files into one.
