cfuson80 0 Posted January 21, 2021 Posted January 21, 2021 I can watch tv using a web browser or emby Theater on a pc, but on my iphone i get Playback Error - no compatible streams are currently available. Does live TV not work on Iphone app? Thanks
Luke 42242 Posted January 22, 2021 Posted January 22, 2021 Hi there, yes it works just fine. Let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
cfuson80 0 Posted January 22, 2021 Author Posted January 22, 2021 attached. Also - I tried to play regular movies I have on there (mp4) and they give the same error Server Version 4.5.3.0 embyserver - Copy.txt hardware_detection-63746928765.txt
Luke 42242 Posted January 23, 2021 Posted January 23, 2021 Are you able to update to Emby Server 4.5.4?
cfuson80 0 Posted January 23, 2021 Author Posted January 23, 2021 Just did - same issue on iPhone any video - works great on pc and Roku
Luke 42242 Posted January 24, 2021 Posted January 24, 2021 16 hours ago, cfuson80 said: Just did - same issue on iPhone any video - works great on pc and Roku Can you please attach a log file example from that? Thanks.
cfuson80 0 Posted January 25, 2021 Author Posted January 25, 2021 Sorry it took so long to get back to you. odd thing - i happened to connect to it with WiFi off and it works. Must be something on my network stopping it. thanks for your help though
JohnsLibrary 9 Posted March 5, 2022 Posted March 5, 2022 I'm having this problem with streaming to both iPhone and iPad. Now I just tried streaming live channels from the PC running Emby and getting the same error about no compatible streams. I've attached the log files for you. hardware_detection-63782075399.txt embyserver.txt
Luke 42242 Posted March 5, 2022 Posted March 5, 2022 37 minutes ago, JohnsLibrary said: I'm having this problem with streaming to both iPhone and iPad. Now I just tried streaming live channels from the PC running Emby and getting the same error about no compatible streams. I've attached the log files for you. hardware_detection-63782075399.txt 142.85 kB · 0 downloads embyserver.txt 1.04 MB · 0 downloads Hi, was there an ffmpeg log? Please attach that as well if there was. Thanks.
JohnsLibrary 9 Posted March 6, 2022 Posted March 6, 2022 Hi, there were several logs for ffmpeg. Some said .graph, I didnt include all of those, jus the last one.. ffmpeg-transcode-80ed40fc-a3c7-4689-a66d-71f145bc2954_1graph.txt ffmpeg-transcode-80ed40fc-a3c7-4689-a66d-71f145bc2954_1.txt ffmpeg-transcode-8b54d79c-e2a2-4aa3-bf59-029dbe2ba2f2_1.txt ffmpeg-transcode-d13bdc13-db4f-4e51-a479-5e5eb28f540d_1.txt
Luke 42242 Posted March 6, 2022 Posted March 6, 2022 9 hours ago, JohnsLibrary said: Hi, there were several logs for ffmpeg. Some said .graph, I didnt include all of those, jus the last one.. ffmpeg-transcode-80ed40fc-a3c7-4689-a66d-71f145bc2954_1graph.txt 27 B · 0 downloads ffmpeg-transcode-80ed40fc-a3c7-4689-a66d-71f145bc2954_1.txt 4 kB · 0 downloads ffmpeg-transcode-8b54d79c-e2a2-4aa3-bf59-029dbe2ba2f2_1.txt 4 kB · 0 downloads ffmpeg-transcode-d13bdc13-db4f-4e51-a479-5e5eb28f540d_1.txt 4 kB · 0 downloads Hi, are you using ServerWMC for live tv? If yes, then it looks like it currently can't be reached and that is your problem. If no, then try removing the ServerWMC plugin, then restart the server and see if that helps.
