CharleyVarrick 284 Posted February 12, 2021 Author Posted February 12, 2021 13 hours ago, mickle026 said: If its not doing anything then tmdb might no longer have the images or restart you server if you havent since running the plugin so changes are committed to the library.db, then every refresh should work as normal. You were right, I restarted my server and refresh metadata now work as expected.
mickle026 653 Posted February 12, 2021 Posted February 12, 2021 7 minutes ago, jlr19 said: You were right, I restarted my server and refresh metadata now work as expected. I am glad everything is back on track to being normal again.
CharleyVarrick 284 Posted February 12, 2021 Author Posted February 12, 2021 (edited) 13 hours ago, mickle026 said: I had limited success with refreshing metadata myself at the higher library level. Always seems to work better done on every movie rather than the library, I have no idea why - but still tedious. Between library-wide refresh (which don't seem to work, at least in my case) and refreshing a single movie at a time (works perfectly but ultra tedious) lays another option: multi selection, that I will try and report on. Edited February 12, 2021 by jlr19
CharleyVarrick 284 Posted February 12, 2021 Author Posted February 12, 2021 Just now, mickle026 said: I am glad everything is back on track to being normal again. +1
CharleyVarrick 284 Posted February 15, 2021 Author Posted February 15, 2021 (edited) On 2/11/2021 at 3:32 PM, mickle026 said: I had limited success with refreshing metadata myself at the higher library level. Always seems to work better done on every movie rather than the library, I have no idea why - but still tedious. I can attest to that; TV shows at the top of the alphabetical order were looking much better, while shows title beginning with letter "M" and beyond were the worst. I lost count of how many M+ shows I had with say, 3 actors showing, refresh metadata (on the show), then refresh and actor count went from 3 to 20. As if library wide metadata refresh always time out after a while, so it always refresh the same a-b-c-d-e and then times out. A Sr noob suggestion: Maybe Emby should do first 10%, pause a few minutes, then do another 10%, pause and so on, instead of trying to do them all at once (and failing). Edited February 15, 2021 by jlr19
CharleyVarrick 284 Posted February 15, 2021 Author Posted February 15, 2021 Or... Then, from folder view of "A" (all movies titles starting with A), refresh metadata I would still need to do 27 MD refresh, but that sure beats doing 15k. 1
Carlo 4561 Posted February 15, 2021 Posted February 15, 2021 That's exactly what I do as it would be cray hard finding movies on my system otherwise with tens of thousands of movies. 1
CharleyVarrick 284 Posted February 16, 2021 Author Posted February 16, 2021 (edited) On 2/12/2021 at 1:44 AM, cayars said: Looks like a contest to see who can find the movie with the most actors listed. It now is ! You Don't Mess with the Zohan, I have 189 listed actors. LOL Edited February 16, 2021 by jlr19 1
Carlo 4561 Posted February 16, 2021 Posted February 16, 2021 2 hours ago, jlr19 said: It now is ! You Don't Mess with the Zohan, I have 189 listed actors. LOL Not sure which to be more impressed with, the number of items or the fact you actually counted them. LOL 2
GrimReaper 4861 Posted February 17, 2021 Posted February 17, 2021 18 hours ago, jlr19 said: It now is ! You Don't Mess with the Zohan, I have 189 listed actors. LOL Looks like your "Missing actors" problem got 'over-solved'© 2
