minikN 0 Posted January 20, 2021 Posted January 20, 2021 Hello, is it possible to somehow show the track number of the title in this view? Background: I'm trying to use Emby for Android to listen to my audio books. My audio books are usually split into ~150 different tracks and all have the same title (the book title). I usually listen to the audio book while in bed trying to sleep. After an hour or so I pause the playback and sleep. The next evening I want to continue listening to it but I'm having a hard time finding the title where I left. Because sometime during the day I close the Emby app and the track where I left off is gone. If I could see the track number I'd simply remember it and had a place to start the next evening. The only way I've found is to tap the 3 dots button and go to "edit metadata", then scroll down to track number. The problem is I only listen to my audio books in offline mode (server not connected). In offline mode the "edit metadata" menu isn't avaiable. Hope I made my problem clear. Cheers.
Luke 42244 Posted January 28, 2021 Posted January 28, 2021 Hi, yes we can look at adding this. Thanks for the feedback.
